700r4 not shifting when cold
Old Mar 11, 2018 | 09:48 PM
Mark4132's Avatar
Whats up guys? so I just bought my first project car witch is a 1992 rs with a 305 and a 700r4 trans. the car has been sitting for about 3 years. I've been going threw it and replacing and fixing what I can and I have gotten the 305 running like a dream. but i cant figure out why the trans dose not want to shift out of first gear when its cold,it will shift but goes all the wat to about 4k rps before it shift and shifts hard. once it warms up shifts pretty good its little slow on shifts some time but other then that perfectly fine. any ideas would be appreciated.
Old Mar 13, 2018 | 09:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 700r4 not shifting when cold
Sounds like the TV valve is hanging up while cold. A line pressure test would show if this is true or not.
RBob.
Old Mar 13, 2018 | 09:33 PM
Mark4132's Avatar
Is there any way to get it to un stick?? And can you change a tv in the vehicle?
Old Mar 14, 2018 | 07:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the engine running disconnect the TV cable at the TB. Then give it some quick pulls and release it. Reconnect to TB and see if that fixes the issue.
Do this with the engine/trans cold as that is when it acts up.
Can R&R the TV valve with the trans in the car. But you may need to drop the valve body.
RBob.
Old Mar 14, 2018 | 04:02 PM
Mark4132's Avatar
Any body know where I can buy a stock replacment valve I'm not looking for any thing fancy,but seems all I'm finding is like.shift kit stuff
Old Mar 16, 2018 | 11:01 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Is the throttle valve cable attached to the throttle body? It is pulled when the throttle is opened.
Did any of your work involve working with the throttle body where it may have been put back on and end up adjusted?
A fluid and filter change involves a pan drop and is a great idea at this point.
Old Mar 17, 2018 | 07:20 AM
Mark4132's Avatar
Yes it's all attached. I just bought a new detent cable gonna try that and a filter change and see what happens. Thanks for replies I do appreciate it!
Old Mar 18, 2018 | 07:52 PM
Mark4132's Avatar
Changed tv cabel and now shifts like a dream
Old Mar 18, 2018 | 08:00 PM
jmd's Avatar
jmd
enjoy it
RavageTheRoad
Jun 2, 2014 08:38 PM
R/T-Z28
Mar 3, 2013 06:17 PM
KARR81
May 23, 2010 10:02 PM
GASGZLR
Mar 10, 2004 03:04 PM
shaocaholica
Oct 14, 2002 01:22 PM
