700R4 or 4L60 Question
Car: 14 & 96 Camry's, 68 C10,70 Z28
Engine: Depends what vehical I'm driving
Transmission: Also depends which vehical
Axle/Gears: Also depends on vehical
Hello all, I have been gathering up much needed info on these trans for a lockup method and the understanding of OD's.
Here is my question. somewhere in what I have been reading someone said he is using a " Manual Body ". Can someone enlighten me on that "Manual Body" thing. thanks
Car: check
Engine: check
Transmission: check
Re: 700R4 or 4L60 Question
A manual valve body causes the transmission to go into the gear that the shift selector position is in.
Need to be sure to start in 1st, then manually shift to each gear. Not fun on the street unless you like to shift. Start in 3rd and it usually takes out the 3/4 clutch pack.
RBob.
RBob.
RBob.
RBob.
thanks again
jigga27
Jun 6, 2001 01:58 PM
90RSconvert
Sep 25, 2000 10:07 AM
