700r4 with reverse manual build
Old Mar 27, 2018 | 09:29 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, I’m dropping off my 700r4 on Friday to a very popular and highly rated performance transmission builder. I’m going with a reverse manual valve body and have a couple questions.
The builder talked about going with a constant pressure valve body and eleminating the tv cable’s control of line pressure. I’m worried that the constant pressure will be too hard on the trans and cause issues. Any thoughts on this?
i also read that the th350 guys have to worry about the trans free wheeling when shifting from 3rd to 2nd and sending shrapnel into their legs, is this an issue with the 700r4? Does the 700r4 engine brake in all gears with a manual valve body?
my final question is on downshifting. a lot of people say to only downshift when at a complete stop but many people also say it’s fine to do if you rev match it, what is the trick to downshifting a reverse manual valve body without causing unnecessary damage to the trans? Thanks
Old Mar 28, 2018 | 06:59 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: 700r4 with reverse manual build
I have one in my car and no TV cable is needed since it's constant pressure. I have a TCI valve body, which provides you with different springs to control shift firmness. I also played with the 2nd & 4th super servo spring, to get it to shift firm but not harsh.
I have the VB with engine braking in all gears, since I only drive on the street now. I downshift while moving just fine, even if I don't rev match exactly it just slows the car down like a normal 700R4.
TCI Part# 376010 -No engine braking
TCI Part# 376015 -With engine braking
Old Mar 28, 2018 | 07:34 AM
TylerSteez's Avatar
Engine: 383 stroker
So just rev match like you’re downshifying a manual then? That’s relieving to hear. How long have you been running the trans now?
Old Mar 28, 2018 | 07:40 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Yep, you got it. I've had it in my car about two years.
Old Mar 28, 2018 | 09:04 AM
TylerSteez's Avatar
Engine: 383 stroker
Awesome, just looked into the kit with engine braking and that’ll be the one I ask the shop to install. Thanks for the help
Old Mar 28, 2018 | 09:30 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Sure, no prob.
Old Apr 4, 2018 | 06:17 AM
Pro Built Automatics's Avatar
Having worked on many hundreds of 700R4's, I would not use a "constant pressure" valve body. Too firm a shift at light throttle and not firm enough at WOT. It is hard on front pump. I have seen many of these failing to keep the transmission alive for very long. For the gentleman getting 2 years and driving it on the street too (not drag racing only) is to me a record. As I have never seen one work for long when used on the street. Even when drag racing only, I prefer to have variable line pressure based on throttle opening, as this is much easier on the geartrain. If you have any questions about this, let me know.
Old Apr 4, 2018 | 09:05 AM
TylerSteez's Avatar
Engine: 383 stroker
The shop already started the build so it looks like I’m locked in with the full pressure valve body. Is there any way to have a reverse manual with a tv cable?
Old Apr 4, 2018 | 10:01 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Makes sense Dana. So which RMVB do you recommend that has variable line pressure abilities? I didn't know one even existed.
Old Apr 4, 2018 | 10:36 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Don't see why they can't change the VB to what you want. I've changed one of my 700R4's from a full manual back to an auto with no problem. You just change out the VB/plates and put the accumulators, checkballs, governor, and pressure regulator back. It's not that hard if the transmissions already open.
Old Apr 4, 2018 | 12:33 PM
I am not aware of a reverse manual valve body that uses the TV cable. As you said you have to put back the 1-2 accumulator. I forgot that they removed this component. No wonder that they shifted so hard at light throttle. It is fine to disable the 4th accumulator, just not 2nd or 3rd. The TransGo modified Shift kit that I make could be setup for "full manual", it would be a forward shift pattern which is the only way to build a full manual in my experience.
Old Apr 4, 2018 | 12:44 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Ok, gotcha. I don't race anymore so a forward pattern is fine. Where is that VB listed on your site? Or, is it a custom request?
I'd like to build another 700r4 and try it.
Old Apr 4, 2018 | 12:46 PM
TylerSteez's Avatar
Engine: 383 stroker
I think I’m gonna run it with the reverse manual and see how it does, the second my front seal pops I will be giving you a call Dana. Thanks for the info
Old Apr 4, 2018 | 12:59 PM
You will use your valve body 1988 & up to make the necessary changes. What is it you want to do exactly??? What is your motor setup? Torque converter diameter and stall? Rear end gear ratio? How you drive? Etc. Do you want a "full manual"? Or a automatic and the ability to manual shift it past 5,000 rpm?
Old Apr 4, 2018 | 01:23 PM
TylerSteez's Avatar
Engine: 383 stroker
street/ strip car, 383 stroker making close to 500hp, 10” converter with a 3000 stall, 3.73 rear, I’m a spirited driver on the street to say the least, full manual is appealing to me for shifting control
Old Apr 4, 2018 | 01:39 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Sounds like you're just wanting to hold any gear for WOT up-shifts. You can do that with a modified VB. If you're driving in traffic, you're not gonna want a RMVB. I do open road cruising, not in traffic.
Old Dec 30, 2024 | 03:45 PM
Cambo123's Avatar
Hey I am planning a VW TDI swap and want to run a 700r4 behind it to a toyota transfer case in a Suzuki Sidekick but I cant run the tv cable because this is drive by wire. The truck will have 35" tires so I am wondering if a manual valve body is my only option?
Thanks , Cambo123
sleprock
Oct 14, 2015 12:20 PM
Thridgen60
Nov 14, 2011 05:12 PM
Kevman
Mar 13, 2009 07:19 PM
murd450
Jan 27, 2009 04:56 PM
Z28cross-fire
Sep 1, 2004 08:48 PM
