Has anyone ran 3.90 gears with their T56
Car: 88 Sport Coupe
Axle/Gears: 4.56
Hey guys,I have an 88 with an Lt1/T56 and 4.56 gears.I was thinking of changing my gears to 4.10 or 3.90. I had a 94 formula Lt1/T56 and it had 3.42's and I changed them to 4.10's.I loved the 4.10's and I also like the 4.56's
but I was just thinking of changing the gears.
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: Has anyone ran 3.90 gears with their T56
I’m in the process of gathering the parts to do a T56 swap in my L98 IROC..are you happy with the overall performance of the 3.89 gears? Many here suggested 4.10, but I’d prefer just a bit more fuel mileage if it doesn’t hurt the overall performance severely going with a 3.77-3.89 gear.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I think they are perfectly fine. I am going to install a procharger, so I based the gears off gas mileage and 4th gen RPM assuming a trap speed.
My Ls1/T56 Iroc has 4.10 gears and they are pretty nice as well! I don't think you will be disappointed with either. I was sway to 3.89 if gas mileage is of any concern.
Car: 1988 IROC-Z
This is exactly what I needed to know..thanks!
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
with the 6 speed and 3.90's im doing 70-80 at 1800 so you could go higher and still have great gas mileage lol
I'll give 2 points of advice on this.
1-Be sure you know which T56 you have. Some have different ratios, and you may want more or less gear. Be aware of it for comparisons
2-Go find a gear ratio calculator online.
Car: 1988 IROC-Z
Both are good suggestions. My T56 came from a ‘94-‘95 F-body, and has the taller 2.66 first gear, which is completely unacceptable with the 2.77 rear currently in the car.
Car: 88 Sport Coupe
Axle/Gears: 4.56
My 88 has 4.56 gears and I love the way it drives and it still only turns 2100 rpm's at 70mph.
I dont think i would put 3.73's behind a t56,I think it would be to close to the 3.42's that came factory behind the T56's. That is why I wanted to hear from guys running 3.90's.I do think the 3.90's would be a good gear.
Car: '89 Firebird
Engine: 7.0L
You've already had 4.10 gear so you know what that is like. 3.90 ratio is only 5% less so you probably won't even know the difference.
If you're going to select a gear ratio then you really need to consider torque applied by the tire to ground. I have 3.73 gears and it works well but my engine makes a lot of torque. If I put 4.56 gears in my car then it would become a spin fest because I could not harness the torque to ground.
ChrisFormula355
Jun 4, 2002 04:31 PM
RB's84camaroF-41
Aftermarket Product Review
Nov 7, 2001 10:30 AM
MrJ
Aug 27, 2001 11:30 AM
Abe91Z28
Dec 30, 2000 11:57 PM
