The Rivet Monster Ate My Twin-Disc Clutch
Old Jun 29, 2018 | 12:49 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Any theories as to what caused this? I'm at a (rare) loss for ideas.
Nothing else was out of place. T/O was new, in good shape, and functioning. Clutch only had 1500 miles on it with almost no abuse other than 3 (fairly mild and successful) passes at the track, but that was last year. Just been putting around on the street since then.
Old Jun 30, 2018 | 07:16 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: The Rivet Monster Ate My Twin-Disc Clutch
Is that a solid hub disc (that lost both friction sides due rivet failure), and a sprung hub on the other?
If so, a good example of NVH every has to go somewhere.
Old Jun 30, 2018 | 10:41 PM
Car: '91 Camaro RS
Yes, but it's a pretty odd way for that to fail ... there was no damage to anything except the friction material rivets. The center rivets and other fasteners are all completely normal.
Old Jul 1, 2018 | 10:04 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Could he as simple as defective rivets and it just finally let go
Old Jul 1, 2018 | 11:35 AM
Car: '91 Camaro RS
Possibly. I'm investigating if excessive play in the input shaft could be at the root of this ...
Old Jul 1, 2018 | 10:54 PM
jmd's Avatar
jmd
Yes, and no. A solid hub disc is always going to have issues that will show first compared to a sprung hub because the energy hits more directly. Same basic logic with a manual trans. car being harder on a rear diff. than an auto car.
I want a clutch that wears evenly and is worn out when it is worn out. Not most parts living, and a select few failing. Running a solid and a sprung is a pretty guaranteed way to isolate failure to one disc ahead of the other.
Once you're floating frictions a tiny bit, the rivets are going to shear a little bit at a time, and the energy usually taken up by a sprung hub will be absorbed by the floating friction on bad rivets. That is what made them appear uniquely failure prone vs. the other disc.
The reason you are probably spot on with the damage being isolated, and not apparently in any of the other rivets may be in junk rivets, but the other disc had built in protection.
Out of curiosity, were both discs entirely marcel-free?
Old Jul 2, 2018 | 10:16 AM
Car: '91 Camaro RS
Yes. I don't think I've ever had a clutch in this car that had Marcels in it, if I can recall correctly.
Old Jul 5, 2018 | 10:39 AM
GeneralDisorder's Avatar
Chinese Rivets?
Have you contacted the manufacturer?
GD
Old Jul 7, 2018 | 11:30 AM
Car: '91 Camaro RS
Chinese Rivets?
GD
Yeah, Spec already sent me an RMA, just gotta get it shipped back. They sound like they're going to take care of it.
One of the reasons I've stuck with Spec all these years, besides the fact that they've generally worked very well ... On the two occasions I had any kind of an issue, they handled it, politely, with no fighting about it. Which, is not exactly par for the course in the performance aftermarket.
grafx
Oct 18, 2024 12:43 PM
super_kev
May 18, 2007 09:44 AM
azcamaro
South West Region
Aug 22, 2006 12:53 PM
Egg83
Dec 5, 2004 11:52 AM
