Need Help / Flywheel - Clutch T5 swap
Old Jul 13, 2018 | 07:48 AM
GermanV8's Avatar
Car: Firebird SE
Engine: 5.0 305 LG4
Transmission: Manual
Axle/Gears: 5 Gears
Hi from Germany (sorry for my bad english first),
My Car: 1985 V8 5.0 S/E LG4 Digit: H
The car was delivered original with Automatic, one Owner before me, swapped an T5 Manual Transmission from a Ford Mustang. Now actually i have problems, the Flywheel or the Clutch. Its noisy ... realy bad. Now i dont want to open Transmission and Clutch before i order the new Parts to change only to measure up what is in there . Could everybody give me an answer which Flywheel and which Clutch Size are correct? When i google oder look at rockauto or ebay, there are many different Flywheels with 153 an 168 Tooth and some different Diameters, the Clutches same Problem, from 10" to 12 3/8" and i dont know which Sizes i need.
Here in Germany it is not easy to become the Parts and so every order will take some weeks vom the States to me, so you see, its not easy for me and i dont want to make a mistake at ordering.
Could anybody help me?
Greetings Sascha
Old Jul 13, 2018 | 08:25 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Need Help / Flywheel - Clutch T5 swap
Wow I would be interested how they managed to get the mustang transmission to work. You wont be able to use the stock clutch as I believe the input shaft has a different number of splines. Because of the oddity of this swap (first I have seen) you probably should take it all apart and look for part numbers on parts. Take lots of pictures.
Old Jul 13, 2018 | 10:01 AM
GermanV8's Avatar
Car: Firebird SE
Engine: 5.0 305 LG4
Axle/Gears: 5 Gears
Uhhhhhh .... this was my apprehension. The problem with the different splines ist the biggest question for me when i will open the system. I will take Pics and let u know about the parts. Greetings from good old germany!
Old Jul 13, 2018 | 10:19 AM
midias's Avatar
Hopefully when you take it apart you will find a camaro or firebird T5 that will be a lot easier.
see if you can identify the T5 being used
http://www.pro-forceperformance.com/...tification.htm
http://www.britishv8.org/articles/bo...t5-id-tags.htm
Old Jul 13, 2018 | 10:24 AM
GermanV8's Avatar
Car: Firebird SE
Engine: 5.0 305 LG4
Axle/Gears: 5 Gears
Hi,
it will be an: 1352-065Ford 1984 Mustang/Capri 5.0 V8U2.762.951.941.341.000.63
Old Jul 13, 2018 | 10:45 AM
GermanV8's Avatar
Car: Firebird SE
Engine: 5.0 305 LG4
Axle/Gears: 5 Gears
Actually ived seen there is a clutch for my Bird with 10 splines on Clutchside / Input .... this could be the middle Part for working . Normally at the Bird are 26 splines ... but there are some clutches in 10,4" dia with 10 splines ..... hmmmmmm this could be the answer.
Old Jul 13, 2018 | 11:08 AM
midias's Avatar
I have seen in other swaps with this trans people use a S10 clutch like this one. How did they adapt the ford bolt pattern to the chevy bell housing?
https://www.summitracing.com/parts/p...olet/model/s10
Old Jul 13, 2018 | 01:37 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
McLeod, at least 3 years ago made a clutch disc for the S10 application, but those are 14 spline input shafts. I have one in my IROC...and am gathering parts for a T56.
Warnd
LSX and LTX Parts
Apr 21, 2013 06:30 PM
1986ROC
Jul 2, 2007 03:19 AM
Patrick007
Feb 17, 2004 09:05 AM
smoke the tires
Feb 10, 2002 09:37 PM
