Tranny fluid for a WC T5?
Car: 92 Z28 convertible
Engine: 305 tpi
Transmission: Auto matic
I recently purchased all of the parts necessary to swap a 700r4 out to a world class T5. I had the speedo gears in the T5 changed to match my 373 rear end. Tranny came back with no fluid in it. I saw here that it takes ATF? Which I assume is automatic tranny fluid, is this correct? This may be a dumb question but I don't want to make that mistake, what tranny fluid goes in there?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Tranny fluid for a WC T5?
ATF Dex Merc III
Mobile 1 is popular
you can also use redline Manual trans fluid it is designed for manual transmissions designed to use auto trans fluid.
Your best bet is to install the trans remove the fill plug put a drain pain under it and fill by dumping in the shifter hole. Much easier cap off when it comes out the fill hole.
Mobile 1 is popular
Car: `86 SS / `87 SS
You're in a cold climate. Just run cheap parts store Dexron-Mercon (Dex-III.)
I like filling from the shifter hole too, but some consoles are more hassle than others.
evilemokid94
Mar 3, 2013 01:15 AM
327_TPI_77_Maro
May 8, 2006 07:37 AM
david auster
Nov 20, 2003 01:28 PM
jigga27
Jan 4, 2003 02:50 AM
breathment
Oct 9, 2001 01:39 PM
