Speedo cable problem
Old Jul 24, 2018 | 08:57 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
My cable appears to be broken off in the housing any clue how to get it out or what i need to replace ?
Old Jul 24, 2018 | 09:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Speedo cable problem
You might be looking at a new Gear. You can pull it and could the teeth I think green cane in 42 & 45
https://m.ebay.com/itm/700R4-Transmi...from=R40&rt=nc
https://m.ebay.com/itm/700R4-Speedom...from=R40&rt=nc
Old Jul 24, 2018 | 09:11 PM
I know its a 3.23 rear so i belive thats green. Also if i pull the housing and gear will the trans fluid leak out ?
Old Jul 24, 2018 | 09:19 PM
Engine: Lb9
Transmission: M20
Yes , but it should be that much.
Old Jul 24, 2018 | 09:21 PM
Okay cool thank you
Old Jul 24, 2018 | 10:32 PM
Drew's Avatar
Grab a rare earth magnet, tweezers, or needle nose pliers and try to pull the old cable spur out of the gear. Might be able to poke it out with a wire from the back side, but I'm not sure the hole goes all the way through.
Old Jul 24, 2018 | 10:44 PM
I tried to pry it out with a small flat head and needle nose pliers but only got a couple little parts. Im gonna take the housing off in the morning and see if im able to poke the rest of it out from the back of the gear
Old Jul 24, 2018 | 11:29 PM
Engine: Lb9
Transmission: M20
I don’t think the hole goes all the way through
Old Jul 24, 2018 | 11:36 PM
Welp guess I'll still take the gear out so I can count the teeth and makesure I get the right one
Toxinz
Jun 27, 2005 03:16 PM
TransAm12sec
Jul 29, 2003 10:33 AM
TBI305Camaro
Mar 17, 2003 02:43 PM
BuckeyeROC
Jul 29, 2002 07:39 AM
Graeme'sFirebird
Jan 21, 2001 01:16 PM
