rear end noise
Old Aug 17, 2018 | 06:56 PM
db057's Avatar
rear end noise
I have a 1992 305 RS... Within the first year I got my camaro which was used, there was this grind/metallic, groan.. when you push on the gas usually about 20 RPMS while in gear, if you shift it to neutral in a hurry,the noise would be gone, but it back into gear at 20 rpms it come back. never figured it out.. but everything/everyone/ resource kept leading to the read axle, maybe pinion/ring , etc.. so I just decided last june, take apart the rear axle and re-do it all with help guides, bought all the tools and calibrations.. so when I took it all apart, nothing honestly looked bad.. the gears didnt look worn (even took pictures), at least not like there would be a problem, the bearings didnt look damages but maybe worn from age but just nothing that something was seriously wrong.. even the axle bearings.. so I replaced it all.. ring/pinion, all the bearings in the carrier and the axle bearings at the far ends). all the gears including the spider gears and did everything with all the tools to put it back together. well, it didnt fix the problem. and youd think maybe i did get some backlash right or something but maybe it wasnt the problem to start. the ONLY thing was the left rear driver axle, the spokes (if im saying it right) at the end of the axle that fits into the gears was ate away, not bad enough it couldnt turn the gear but obviously was worn quite a bit. but i dididnt have a new axle and it turned th egear so it was put back in, the right one looked perfect!..
so lately, when I turn the car i think its to the right, in gear or not in gear, you can hear that groan noise from the rear, sounds like driver rear... but when you turn it the other way you dont.. you have to go fast enough at least id say 20 -30 mph to get it to make that noise.. so. could it be that axle? even though it turns the gears, do you think tis so worn its making noise, or is the bearing suddently bad? which the old didnt look bad at all... i dont want to just go buy an axle even though it should be replaced in time.. but any ideas.. appreciate it. thanks
Old Aug 17, 2018 | 09:17 PM
Re: rear end noise
Groaning noise when going around a corner = a clutch-type posi that needs additive, most commonly
Try just dumping a bottle of it in there. If of course, it's a posi at all.
If it's not a posi to begin with, then the side gears and carrier are wiped out.
Probably not an axle.
Old Aug 17, 2018 | 09:29 PM
db057's Avatar
Re: rear end noise
I think Posi. I had overhauled the entire axle, except the axle shafts. all the bearings were replaces the gears, the ring and pinion and seals, everything. the original noise never went away.. im not sure if it made that noise on the turns back before I overhauled it to be honest.. i just noticed it and wondered but it could have been doing it even before I overhauled it.. ill show pics of how it looks before i overhauled it.. so you can see what type of differential. but this is the old gears in the pic. i didnt take any new pictures or of the axle shaft.. when I had it all apart last June.
Attached Thumbnails rear end noise-20151206_161124.jpg   rear end noise-20151206_161047.jpg
Old Aug 18, 2018 | 07:28 AM
Re: rear end noise
Not a posi. A posi would have clutches and springs visible in the window. Like this:
The carrier is probably trashed where the side gear runs against it. Typical result of a sustained one-wheel-peel. It would be on the left side if it makes the noise going around a right corner. The OWP would have been donuts with the right side first. (steering wheel to the left)
Could be something about the axles with the damaged splines; can't imagine how, but putting damaged parts back in is never a recipe for assured success. Axles aren't too $$$ though, and very easy to change, so you could try that. At least you have 28-spline ones, so you get to buy the better ones as a shot in the dark and don't have to buy garbage 26-spline and hope for the best.
For example https://www.summitracing.com/parts/aly-17126/overview/ Replace em both, and the bearings & seals as well. No guarantees but you clearly need at least one anyway.
iroczrockz
Nov 21, 2002 08:38 AM
Hot Wheeler
Jul 30, 2002 09:34 PM
smoke the tires
Apr 10, 2002 04:45 PM
zimmer
Mar 26, 2002 11:24 PM
david foraker
Jan 23, 2001 04:47 PM
