91 camaro with 700r4 -stalls in gear at idle
Car: 91 Camaro RS convertible,
Engine: 5.0
Axle/Gears: limited slip 2.73
what can cause TCC to engage at idle with brake applied? overide switch fault?, or leaking solenoid valve? anything else?
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: 91 camaro with 700r4 -stalls in gear at idle
Unplug the four pin connector on the driver side of the transmission and see if it stop the converter lockup
Engine: 5.0
Thanks Antoine, thats my next move, gotta jack it up and do it, getting too old for this. how do you get to senior member status? God Bless! Will post up when I get it done. Hope that does it. I dont compute every day, sorry for the delayed response.
one wheel peel
06-04-2008 07:58 PM
