1985 transmission IDentification 700 or 200
Old Dec 14, 2018 | 01:34 PM
windsurfer's Avatar
Was there only the 700 R4 transmission available from factory in 1985. A transmission repair man has asked if it was a 200 or 700. He says by the gear selection , 1,2,Drive and OD it is a 200. Sounds confusing to me. Any clarification would be appreciated. Thanks, Frank
Old Dec 14, 2018 | 02:23 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: 1985 transmission IDentification 700 or 200
Only time I recollect the 2004r being used in a thirdgen was on the 89TTA. Many people have used them it just didn't come stock on our cars.
Old Dec 14, 2018 | 02:57 PM
Drew's Avatar
From 83-92 all the V8s used the 700R4. The shifter on some reads 1, 2, 3, OD, others read 1, 2, D, OD. Doesn't matter it's still a 700R4.
Old Dec 14, 2018 | 03:01 PM
windsurfer's Avatar
Thank you for that information. Mine is a 6 cylinder so did they also only have a 700?
Old Dec 14, 2018 | 03:17 PM
Drew's Avatar
If it's a 4spd overdrive, probably. All else fails, search google for an auto trans pan ID chart, and get under it and look at the pan and count the bolts. 700r4 is a square, flat pan with 16? bolts. 2004r looks more like Nevada.
Old Dec 15, 2018 | 05:44 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Yep, also all V6 models use the 700R4, but in a smaller bellhousing than the V8s. They are not interchangeable.
FBODY-ADDICT
May 19, 2011 07:25 PM
Xanath
Jul 2, 2008 06:15 PM
dennisbernal91z
Dec 23, 2007 05:24 PM
tpsierra
Mar 19, 2001 11:09 PM
Stormshadow GTA
Mar 18, 2001 10:55 PM
