700r4 Lost 1st Gear Engine Braking
Old Apr 17, 2019 | 05:59 AM
F-body driver's Avatar
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Hello
I've lost engine braking in 1st gear only
Trans Go Shift kit 2-3 in Manual configuration installed
Fluid is red
Lucas Additive in the pan
After the shift kit installation I had engine braking in all the gears. After 40 miles 1st gear freewheels
Old Apr 18, 2019 | 04:35 PM
Re: 700r4 Lost 1st Gear Engine Braking
Anyone?
I've checked the fluid today and is not cherry red anymore...it's kinda pink but still clear and transparent.
Fluid il clear but left some black stuff around the rag
Old Apr 20, 2019 | 02:49 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Originally Posted by F-body driver
Anyone?
Low reverse clutch pack is responsible for engine breaking. Might have an issue there.
Old Apr 20, 2019 | 03:00 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Anyone?
Low reverse clutch pack is responsible for engine breaking. Might have an issue there. Did you rebuild it yourself?
Old Apr 21, 2019 | 07:09 AM
I'm experiecing long delays in reverse gear engaging when cold.
2nd and 3rd gear have engine braking as normal
Old Oct 30, 2019 | 07:27 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
you need to pull out the shift kit and find the problem you created.
Old Oct 30, 2019 | 09:04 PM
skinny z's Avatar
When my 700 did that, (no engine braking in manual 1st) it was the low/reverse sprag. It's the one way clutch that provides engine braking in manual 1st. Might also explain the reverse issue you're having. They break. Mine failed right after a rebuild and shift kit install. Could have been my driving habits. Could have been poor assembly. After another rebuild, that trans lasted almost forever.
Forward Sprag
EDIT: Didn't see that this thread was from April. Hope the OP has it figured out.
Old Oct 31, 2019 | 01:14 AM
Pro Built Automatics's Avatar
If you are having problems now with it. It sounds like you have lost the low reverse clutch pack. When you have it apart, I will give you some help as to how to prevent this from happening again. Was the valve body (since this is a 1987 unit) the first design GM or second design GM valve body?
Old Jan 6, 2021 | 05:46 PM
I solved the problem:
Added a bottle of Lucas Trans Slip fix, installed a Corvette Servo and now it shifts perfect with engine braking in all the gears
Old Jan 6, 2021 | 06:00 PM
vorteciroc's Avatar
Top Answer: 1
Lucas Trans Slip fix is a very bad idea...
91z28350
Feb 9, 2004 01:41 PM
tbfirebird
May 13, 2003 08:44 PM
paintshooter
Sep 23, 2002 07:26 PM
sancho
Aug 1, 2002 03:48 PM
