700R4 No Overdrive?
Old May 3, 2019 | 07:12 PM
TheDark1's Avatar
700R4 No Overdrive?
My Camaro has a 700R4 trans with a electronic lockup, I have no overdrive in it due to no ECM. (PO removed TPI and went carbed SBC with mechanical fuel system). There isnt a ECM in the car, that being said how can I get 4th gear without the ECM?
Old May 3, 2019 | 07:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 700R4 No Overdrive?
Toggle switch, or tci makes a lockup kit.
Old May 3, 2019 | 07:34 PM
TheDark1's Avatar
So all I have to do is run power wire from batt to plug in on trans with a switch?
Old May 3, 2019 | 08:11 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tran...51750-tcc.html
Old May 4, 2019 | 08:39 PM
Pro Built Automatics's Avatar
The electronics control lockup only. This has nothing to do with not having overdrive. You will have to install a 0-300 psi. gauge on this to get the readings on what pressure you have to see what is going on here.
Jim Landy
Oct 20, 2001 03:15 AM
88TPI406GTA
Sep 27, 2001 10:54 PM
chevyguy16
Feb 23, 2001 01:54 PM
mike ghoul
Sep 23, 2000 01:32 AM
