correct flywheel
correct flywheel
Have a 97 350 chevy engine. Using 10,5 clutch. Installed a 14088647N flywheel. 153 tooth . Using a powermaster starter for 153 or 168 tooth flywheel. Starter instructions say there should be 1/16" clearance between retracted starter gear and flywheel. I have 1/4". Is this flywheel sized differently than the more standard 14088650? Can't find any info on the 14088647N .HELP, Thanks
Car: `86 SS / `87 SS
Re: correct flywheel
Both 14088647N and 14088650 are 153 tooth, 12.8" dia.
Powermaster makes some starters which bolt to the (parallel) bolt holes for a 153 tooth flywheel, and they can use a second set of holes (in the starter case block) to mount further out to suite a 168 tooth wheel. But that should be greater than 1/4" difference.
I would say you have a questionable starter fitment situation, but no pics and no PN for the starter mean more questions than answers.
rockstarr4
Nov 30, 2010 11:36 AM
project_91RS
Sep 20, 2005 05:00 AM
84maroman
Apr 24, 2003 06:39 PM
Damon
Mar 11, 2002 01:29 PM
