10 bolt for Autocross?
Old Nov 5, 2019 | 07:18 PM
McLovin1181's Avatar
I have a 5.0 tbi 92 RS that I only AutoX.
The factory 7.625 10 bolt has bad wheel bearings and I want to rebuild it.
It's a 2.73 open diff drum rear.
Can a 7.625 10 bolt handle 350 horsepower?
At the AutoX we never do hard launches and any 100% power usage is always done when moving.
Ex: we may rapidly floor it for 1-2 seconds, but never from a dead stop.
The current 170hp 5.0 won't break it, but I'll be using a L33 5.3L next season.(350-380HP)
My plan was putting in:
3.42s
Eaton True-track
New 28spline axles
New bearings/seals
And putting together some disk brakes.
Is this a wasted effort?
Old Nov 6, 2019 | 08:03 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Re: 10 bolt for Autocross?
3.42s
Eaton True-track
New 28spline axles
New bearings/seals
For autocross this will hold up well. I have pretty much the same setup in my car except I have a torsen posi unit. For the cost I had about $350 in rebuilding mine including buying the posi unit and new pads and rotors.The 10 bolt will be fine!
Old Nov 6, 2019 | 07:01 PM
What power, gearing and tires are you using?
Old Nov 6, 2019 | 07:16 PM
cmiller2014's Avatar
Car: 1991 Camaro Z28
Engine: 6.0 LS
Axle/Gears: 9" Rear w/ 3.70 TruTrac
Just as an FYI you might want to do a little research on changing gears since you have a 2.73 currently. It's pretty well documented here: https://www.thirdgen.org/forums/tran...ear-ratio.html
The problem is you have a 2 series rear instead of a 3. You can go up to 3:08 with no problem but any higher than that and you'll want to make sure you do your homework so you aren't buying parts twice.
Old Nov 6, 2019 | 07:43 PM
Car: 85 Berlinetta
I only have around 200hp. 3:42 gears and 245/55/16 tires. I am going to 275/40/18’s.
Old Nov 6, 2019 | 09:19 PM
It was my understanding that all the axle housings are the same and the only difference is the differential itself.
Since im going with a 3 series True Track, 3.42s should fit.
If I was keeping the stock diff ya, 3.08 would be the largest I could go.
Old Nov 6, 2019 | 09:20 PM
Engine: 6.0 LS
You're correct. My bad man I missed the point where you're going with an Eaton
Old Nov 6, 2019 | 10:31 PM
No problem, I'm just gathering as much data/opinions as I can.
Still unsure if building up a small 10 bolt is worth it
VS spending more on a 8.8 build.
Old Nov 10, 2019 | 07:01 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
You can run a rear gear higher than 3.08 in a series 2 carrier. You just need to make sure you get the set with the thicker ring gear.
Old Nov 10, 2019 | 03:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The ten bolt will hold up fine behind a 305 TBI. I autocrossed with hot street 355s and a 383 with street tires and never broke the rear. Grab one of the thick aluminum covers to aid in draining and refilling fluid.
94-6spd
Apr 4, 2022 04:18 PM
Demon355
Sep 7, 2007 04:13 PM
m300slr
Aug 29, 2005 11:31 AM
JeremyNYR
Mar 25, 2004 06:36 PM
rocky383
Apr 30, 2002 09:43 PM
