Help T5 wont go into gear
Car: 87' Iroc-z28
Engine: 350 TPI (L98)
Transmission: T-5 Non W/C
Hello, i recently swapped a lb9 for a l98 and before the swap my trans shifted fine, after the swap and an instillation of a new flywheel, clutch, pressure plate, and T/O bearing the trans wont shift into gears with the car running, i double checked the T/O bearing and it was installed correctly, i bled the slave cylinder and it still wont go into gear, the clutch fork travels about an inch. if i shut the car off it shifts into gear fine, i can start it in gear and the wheels spin even though my foot is on the clutch, the flywheel and clutch kit is from perfection clutches. i was starting to wonder if the issues is that the kit came with the wrong T/O bearing, i dont have the old one anymore so i cant match them up, i was hopping someone might have experianced this issue before.
Re: Help T5 wont go into gear
Sounds more like something wrong with the pilot bearing or bushing. Which did you use?
Car: 87' Iroc-z28
Did it go in smoothly? No damage to it that might have closed up its hole? Any chance the tip of the clutch gear is binding in it?
Car: 87' Iroc-z28
it went in pretty easily, no damage, How would I check if the clutch gear is binding in it? Also the rod from my slave cylinder doesn?t sit in the fork straight, it comes at a angle slightly and sits in the dimple for it. Is that normal? Or are they supposed to be straight?
Take the drive shaft out of the rear but leave it in the transmission, have your assistant sit in the car and push in the clutch, and try to turn the DS. Might take putting the U-joint caps back on and using a piece of pipe or something. If it's real stiff, try loosening the trans bolts almost all the way, sliding the trans back about three quarters of an inch, and repeat the test. Might have to undo the trans mount somewhat to let it slide rearward. If it then turns easier, it's a pilot problem. If it still doesn't, it's something about the clutch.
Either the clutch isn't releasing, or the pilot is binding on the clutch gear... those are really about the only things that can cause your problem.
Car: 87' Iroc-z28
Also I assume it has to be in gear?
Car: 87' Iroc-z28
Shouldn't matter with a new clutch. Might allow the SC to reach the end of its travel and maybe even explode (though probably not) when the clutch wears out.
Car: 87' Iroc-z28
- I just turned the drive shaft in 4th with clutch pedal to the floor it turns smoothly. With foot off the clutch it doesn?t want to move at all
One would think so. If the clutch lets go well enough that you can turn the whole transmission by hand, you'd think it would also let go enough to let the transmission shift.
Put the DS back together; put it in 5th; start it with the clutch pushed in; hold it in and let it run like that for a few minutes. See if that helps. Maybe it'll wear off any rough edges or whatever.
Car: 87' Iroc-z28
Car: 87' Iroc-z28
I have fixed the issue, clutch fork and pivot ball were worn, also the clutch fork was not positioned correctly on pivot ball, hence why the slave rod sat off to the side.
Thank you sofa helping!
BeatUpTransAm
Mar 30, 2017 04:38 PM
TBIfly
Mar 24, 2003 06:34 AM
