1989 Steering Column help
Old Jun 9, 2020 | 03:13 PM
Lively's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Transmission: 5 Speed Manual
First i will start with my problem's...
  • Turn signal switch is missing
  • puller broken off in pivot pin
  • MOST IMPORTANTLY the steering wheel wobbles at the "shaft?". i dont believe its the 4 bolts that need to be tightened because from the videos i watched they all shake from the neck up... mine shakes only at the end. I believe it may be the u-joint? idk
So i was looking into replacing the whole column to hopefully bypass all the issues but ive ready somewhere that the 1989 column is different then the years before and after. Anyone know how to either repair my issue or if i can use a different column... I dont have an airbag got it the a aftermarket wheel, ignition is broken previous owner installed a push start (hoping to fix all that too after). Hopefully someone here has had this issue before or at least knows a solution cause im stumped... and i gotta figure out how to remove that broken pivot pin if its repairable.
Just got back from a pickyourpart where they had 1 1989 firebird and the only thing missing really was the column!!!!
Old Jun 11, 2020 | 07:55 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: 1989 Steering Column help
First off welcome to the forum, secondly take a bit of time and fill out your profile so people will know more about your car.
Turn signal stalks can be purchased in the aftermarket and after the cruise wire (if equipped) is snaked through it just snaps in.
The piece stuck in the pivot pin can be extracted, I had to do it twice when I rebuilt my column.
The four bolts refer to the tilt wobble, but I believe your issue is related to one of the bearings is missing or really worn out.
As for the column being different, 1989 was the first year for the PASS-KEY ignition lock system, also called VATS (vehicle anti theft system) here in the forum. If the previous owner disabled or bypassed that system, then you could go with an older column. Vats was programmed into the ECU, so if you no longer have the factory computer then youre good to go with an older column too. Only difference in the older columns is there is one for automatics and one for manuals, with the manual column having a lever behind the ignition key that needs to be pressed down to remove the key.
Stevenmunoz
Jun 9, 2018 02:52 AM
Brian Felts
Oct 20, 2007 10:23 AM
billum
Apr 19, 2006 12:18 PM
chad1966
Jan 16, 2006 10:56 AM
killer1958
Jul 7, 2005 03:01 PM
