clutch problem need help please
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
yesterday my clutch was fine then today when i was out driving i noticed that i had to put the pedal right to the floor to get the car to go into gear. i got the car home and looked at the resevour and it was a little low so i topped it up. after that i went in the house then i went out to pick up my brother and i pushed the clutch in to start the car and heard a clunk sound. then i let the clutch out and pushed it in again. there was resistance but the clutch did not disengage. i got out and looked under the car and none of the hydraulic lines were leaking. i have not tried to bleed it yet because it is snowing here. any ideas what happened?
thank you
Paul
thank you
Paul
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
i started the car with the shifter in first and the clutch right to the floor and it started perfectly. as soon as i let the clutch out a little bit the car started to move. the clutch works just not much
theshackle
Aug 31, 2015 10:47 AM
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
