ECM thinks car is in Drive no matter what
Old Nov 26, 2020 | 09:07 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So my EBL WUD is showing me that the ECM thinks the 700r4 is in drive no matter what gear I am in. I checked the trans, and the 2 plugs on the driver side (square 4) and VSS plug are both plugged in. Is there something internal that has probably gone bad or broken? I am considering taking it to a shop to have the trans looked at if that may be the case, but do not know if there is a simple solution I that can be DIY.
Old Nov 26, 2020 | 09:46 PM
GeneralDisorder's Avatar
Re: ECM thinks car is in Drive no matter what
The switch is on the shifter under the console. It has nothing to do with anything inside the transmission, or the wiring to the transmission.
GD
Old Nov 26, 2020 | 10:50 PM
msammy93's Avatar
Engine: 383 TPI
GD
Okay, I see the switch there, how do I diagnose what's wrong with it?
The backup lights also are not working when it's in reverse so there is definitely something wrong with the switch.
I'm pretty handy with a multimeter if there is a way to check it with that
Old Nov 26, 2020 | 11:25 PM
I would start by making sure the connection is clean and tight. If the neutral switch and the backup lights are both inoperative that would seems to suggest a connection problem with the switch.
Beyond that I would have to consult a diagram. I have not had an issue with mine in that area so I'm not entirely sure of the circuit layout. Do you have a service manual?
GD
Old Nov 26, 2020 | 11:27 PM
msammy93's Avatar
Engine: 383 TPI
GD
Not yet, I bought a brand new sealed 88 Firebird manual off eBay a few days ago. Cost a pretty penny $200, but everyone here always refers to me it so should be worth it. Thanks for giving me a tip on what the problem is, I'll wait till the service manual gets here and look though it.
Old Nov 27, 2020 | 12:24 AM
ULTM8Z's Avatar
https://tpiparts.net/1227165_pinout_diagram
In the upper left of the page, you'll see the Park/Neutral input at terminal B10 at the ECM. If you access the ECM and take a multi-meter from B10 to ground to measure resistance, you should see it change between a few milliohms and open circuit as you shift out of park/neutral into gear. If you don't see this change in resistance as you shift the gear lever, you have some problem with the switch and/or wiring between that switch and the ECM or the switch and ground. I believe the switch is supposed to ground B10 when you go into gear.
Old Nov 27, 2020 | 12:27 AM
msammy93's Avatar
Engine: 383 TPI
Thanks so much, I will check it tomorrow!
Old Nov 27, 2020 | 09:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is the opposite, open input is in drive, grounded input is in P/N. On stick shift cars GM just left the input open, so they are basically in drive all of the time.
msammy, you may find that the tab to move the switch has broken off. So the shifter isn't moving the switch.
RBob.
Old Nov 27, 2020 | 12:28 PM
ULTM8Z's Avatar
RBob.
Ah, I stand corrected!
Caidhlaoch
Dec 24, 2019 06:39 PM
Kat
Aug 5, 2010 02:10 PM
jonarotz
Oct 14, 2007 09:50 PM
eric305TPI
Nov 13, 2004 04:38 PM
