9 bolt
Old May 6, 2021 | 02:14 PM
BigBloc305's Avatar
9 bolt
Hey guys I am new here. Modding my 86 Berlinetta I pulled out from the mud. Was recently at a yard and found a smashed 89 IROC with the rear intact. Its a Borg Warner 9 inch with disk brakes. Started to take it apart and order parts for the rebuild. The gears are still good however, the cones are both bottomed out. Does this mean I need a new carrier or just the cones? I had planned to grind the carrier ridge down when I installed the new cones from 9bolt.com and was wondering why Id need a new carrier as some of the articles I've read have stated. Any help or info about the 9 bolt would also be helpful as I'm very familiar with the 10 bolt but not the 9.
Old May 6, 2021 | 03:10 PM
ResIpsa's Avatar
Car: 1987 Formula 350
Engine: TPI 383 Stroker
Re: 9 bolt
My suggestion would be not to waste your time rebuilding cones. Get a Torque Lock helical (torsen) limited slip differential like many on this forum have already done. The only modification needed on some cars is a little grinding of the pinon gear for clearance.
They can be ordered from 9 Bolt (I believe) or on ebay from Australia.
Keep all the strength of the 9 bolt with a nearly indestructible LSD.
https://www.thirdgen.org/forums/tran...n-upgrade.html
https://www.thirdgen.org/forums/tran...rg-warner.html
https://www.thirdgen.org/forums/tran...installed.html
Old May 6, 2021 | 03:40 PM
BigBloc305's Avatar
Re: 9 bolt
Sounds good! Question though, will my original 2.77 gears work or will i need a higher ratio? Read something about a series 2 vs series 3 ring and pinion.
Old May 7, 2021 | 07:35 AM
ResIpsa's Avatar
Re: 9 bolt
Yes. That should work. You probably will need to grind the top of the pinion for clearance. It is really easy to do and I did not even pull mine from the car. I found using a 4 inch flap disk on an angle grinder worked best.
Old May 7, 2021 | 07:49 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 9 bolt
I think there is a gear split like most other rearends but to be safe check 9bolt.com or the 9 bolt FAQ here
Old May 7, 2021 | 01:09 PM
Re: 9 bolt
The series break in the 9-bolt is between 3.08 and 3.27.
You can't use a 3 series carrier with 2 series gears because the flange on it that the ring gear mounts to, is too close to the pinion. That's what carrier "series" is all about. You can use a 3 series gearset on a 2 series carrier, if you either put a spacer behind the ring gear (not all rears accommodate this gracefully) or use extra-thick "special" gears. To my knowledge neither of those things is available for the 9-bolt. I have no clue whether you can buy a 2 series Torsen carrier.
That 89 9-bolt is GOLD. People will give you their left reproductive organ for those brakes. If you can't use it because it has a crappy ratio, you can almost certainly make money on parting it out.
Old May 7, 2021 | 04:46 PM
vorteciroc's Avatar
Top Answer: 1
Re: 9 bolt
The PBR aluminum caliper brakes???
Old May 7, 2021 | 09:04 PM
TTOP350's Avatar
Re: 9 bolt
Yup, and the year with 2 styles of backing plate for the 9bolt/pbr disc. with (early) and without (late) dust shield.
Old May 7, 2021 | 10:39 PM
vorteciroc's Avatar
Top Answer: 1
Re: 9 bolt
Then I have to assume, people are only after the Backing-Plates...
Since all of the other brake components are still available (reman./ aftermarket).
I have been cutting my own "flat-plate" steel backing-plates for the PBR Brakes for the last 10 years now.
Unless someone is restoring a 3rd gen to as close to completely stock as possible...
I see no point in hunting-down the original Backing-Plates (and paying crazy prices for them).
Demon355
Sep 7, 2007 04:13 PM
DeHoyos
Oct 26, 2006 05:26 AM
87TAairlineyard
Jan 13, 2006 05:01 PM
ron_firebird_91
Jul 12, 2004 07:49 PM
snapping turtle
Mar 8, 2004 09:27 PM
