a mustang shift lever on a third gen???
Old Jan 20, 2002 | 02:28 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
yes, for the T-5 equipped third gens, will it fit?
i love it's short throw and angle, even the handle is cool.
(don't worry that's all i like from the musWang"
what do you think fellas?
Fernando.
Old Jan 20, 2002 | 03:10 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
If your going to get a Mustang shifter (assuming it fits) get a Steeda Triax. My brother has one on his '87 5.0 and its spectacular. It's a rock solid feel.
Old Jan 20, 2002 | 03:37 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
right on bro.
Fern.
Old Jan 20, 2002 | 06:01 PM
plain82's Avatar
I had one on mine, but you need to do some work to make it fit. You will need to drill 2 more holes in the base, where it attaches to the trans. The you need to enlarge the 2 rear holes. I found this out after taking it completely apart, only to find that the base for the Mustang shifter is taller. After that, remove the 2 bolts that hold the stem to the base. You need to turn the stem around because otherwise it just hits the side of the console. Plus the fact that you can't use your upper shift boot. Of course, you could just buy a Hurst or B&M shifter and get the same result. But, you are correct. I did like the way it looked. Just a lot of hassle to make it work.
Old Jan 20, 2002 | 06:57 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
so...
a little time, tools, common sense and patience is all it takes?
man i'm goin' for it. thanks for the tip bro.
FERNANDO.
RedLeader289
Jan 22, 2016 03:05 PM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
