Car doesn’t want to go into park
Old Jun 4, 2023 | 01:05 PM
GingerHunter's Avatar
Car: 1991 Pontiac Firebird Convertible
Engine: 5.0L V8 (305)
Transmission: Automatic
Axle/Gears: GM gov-loc Posi 3:42 ratio
So all of the sudden yesterday my 91 Firebird doesn’t want to go into park has kind of a hot electrical smell and there is some type of piece of plastic sticking out the side of the console. Does anyone have a clue what this is? I recently purchased the Haynes manual for my car. Unfortunately, the one thing it does not show is how to open up the console and get inside to the shifter mechanism…Any help would be greatly appreciated.
Old Jun 5, 2023 | 12:14 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: Car doesn’t want to go into park
Appears to be related to your question about removing the console on your Firebird
https://www.thirdgen.org/forums/inte...ng-center.html
I picture the plastic thing too would be helpful if you get a chance.
Old Jun 5, 2023 | 02:38 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Shift back and forth between reverse and drive. While doing this watch your steering column, you should see a piece of the column rotate. Try "helping" that rotating piece on the column while shifting into park. They can get in a bind sometimes.
Sounds like part of the bracket that holds the cable (that goes to the column) may have broken. If you remove the shifter plate you can see everything in there and figure out what's up.
Old Jun 6, 2023 | 07:54 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Pictures?
HULK
May 13, 2004 11:55 AM
Faded
Oct 5, 2003 04:28 PM
KCobain147
Mar 8, 2002 09:31 AM
Mongoose
Jan 30, 2002 02:26 AM
Trevor K
Jul 13, 2001 04:51 PM
