Changing rear diff oil no fill hole
Old Oct 21, 2023 | 12:45 PM
Chaddyboy's Avatar
So I decided to change the rear diff oil bought a nice new chrome cover ect.Now ive done this before which is straight forward. It's 9 bolt I borg Wagner.The cover has a drain plug so I assume I fill there as well as I don't see a fill hole on the pumpkin.
Old Oct 21, 2023 | 12:50 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Changing rear diff oil no fill hole
The fill hole is on the passenger side of the differential. ALL differentials on these cars have it...
Old Oct 21, 2023 | 12:59 PM
Chaddyboy's Avatar
I edited my post seems its a 9 bolt borg wagner
Old Oct 21, 2023 | 01:07 PM
T.L.'s Avatar
Yeah, you gotta use the stock cover on the 9-bolt (or one with a fill hole)...
Old Oct 21, 2023 | 03:55 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Does that new cover actually fit the 9 bolt rear? Hot setup would be a finned aluminum cover with a fill and drain plug.
Old Oct 21, 2023 | 04:08 PM
As long as the fill hole in the cover is at the same height as the one in the stock cover, it'll be fine. Hopefully it has something intelligent instead of the stuuuupid stock 9-bolt rubber plug thing. A pipe plug is SO much better.
Obviously you want to get as much fluid into it as the stock one allowed. But you don't want TOO much; if the level is above the bottom of the axle tubes, then they'll be full of fluid ALL the time, and the seals will leeeeek it out WITHOUT MERCY. You don't want to fill it above that level.
Old Oct 21, 2023 | 04:24 PM
Chaddyboy's Avatar
nope new cover has 10 holes so I screwed up ..Or actually the last owner must of swapped out the rear as I don't think irocs came with borg Wagner.
Old Oct 21, 2023 | 04:27 PM
Chaddyboy's Avatar
There is no fill hole.in the new cover.I screwed up thinking my iroc had a 10 bolt like.my last one.
Old Oct 22, 2023 | 06:44 AM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Then this might be your only choice other than the stock one: https://www.taperformance.com/prodde...prod=TA%5F1802
Old Oct 22, 2023 | 03:11 PM
I don't think
I do that all the time. Both of them. Doesn't seem to matter thinking, or not, about what; just, thinking or not, instead of looking and getting the facts, is the problem.
IROCs from 87 to 89, and maybe a few 90s, often came with 9-bolts. Especially the TPI cars. The carb and TBI ones more usually had 10-bolts. Still, not hard to stick your head up under there and check.
Always LOOK AT your car before you buy parts for it. I don't really want to be a jerk or anything (it just comes naturally to me), but it's hard to be sympathetic toward you when you could have just counted the bolts.
Old Oct 22, 2023 | 03:50 PM
Chaddyboy's Avatar
You are correct and I did count the bolts as low to the ground as I could go for my age lol.However I also assumed it was a 10 bolt as my other camaro was.Oh well you are correct never assume.
fastlane350
Mar 16, 2011 04:57 PM
joshwilson3
Jun 27, 2010 06:13 PM
Bigwavedave
Jun 13, 2010 04:04 PM
xChAoSx
Aug 29, 2008 09:04 PM
foney_email
Sep 27, 2002 08:16 AM
