So i just finnished my auto to t56 swap and its grinding in al gears expecially when i downshift. Almost impossible to get from 3th to 2th and impossible to get in first, i have to almost stand still to get it in.
When at stand still i can shift it smoothly in al gears without grinding so i dont think its a clutch problem but probably the syncro's right? I have third gen pedals with 4th gen hydraulics.
Dont know anything about the transmission but that its from a 95 camaro and bought it from ebay...
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
Start thinking that then. It's a clutch problem.i dont think its a clutch problem
Really?? ALL 7 OF THEM???probably the syncro's right?
No.
What did you put in the crank; a pilot bushing, or a bearing?
No.
The pilot bushing that came with the clutch kit.Originally Posted by sofakingdom
Start thinking that then. It's a clutch problem.Really?? ALL 7 OF THEM???
No.
I assumed it was the syncro's because its an ebay transmission that came from a wrecking yard seller
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
Hydraulics bled really well and new?
Quote:
Brand new pre bled 4th gen hydraulicsOriginally Posted by TTOP350
Hydraulics bled really well and new? Did you measure and install/shim the slave cylinder correctly? I agree with Sofa. Sounds like clutch is not disengaging correctly.
OP, you said it's from a '95, so assuming you are using a pull-type clutch with an external slave cylinder. There aren't any shims for the slave/throwout bearing on that style, so don't worry about that.
Sounds like a clutch disengagement/dragging issue. With the car stopped and running, clutch in, hard to get into 1st or reverse from neutral but easy if the engine is off, it's a clutch issue. A few things to check:
-Is the little plastic cap on the end of the slave cylinder push rod in place? Sometimes that mistakenly gets discarded when installing a new slave cylinder
-Are you using 4th gen pedals? The clutch master cylinder connection point on the clutch pedal is different between 3rd and 4th gen.
-What clutch are you using?
I'm using a '95 T56 in my '89, rebuilt by Tick Performance and using a Spec Stage 1 clutch. I was having similar issues with clutch disengagement. I talked to Tick and they said that the Spec clutches typically require a little more travel than the stock 4th gen hydraulics can do and they recommended using their adjustable master cylinder. I did that and the problem went away.
No with the car stopped and running its easy to go in al gears its only when im driving that the grinding occurs (only driven a few test miles).Originally Posted by TransamGTA350
OP, you said it's from a '95, so assuming you are using a pull-type clutch with an external slave cylinder. There aren't any shims for the slave/throwout bearing on that style, so don't worry about that.Sounds like a clutch disengagement/dragging issue. With the car stopped and running, clutch in, hard to get into 1st or reverse from neutral but easy if the engine is off, it's a clutch issue. A few things to check:
Plastic cap is in place.
3th gen pedals.
Stock lt1 clutch from perfection (rockauto)
Quote:
You are correct. Completely forgot about the early T56. Thanks for the correction.Originally Posted by TransamGTA350
OP, you said it's from a '95, so assuming you are using a pull-type clutch with an external slave cylinder. There aren't any shims for the slave/throwout bearing on that style, so don't worry about that.Quote:
3th gen pedals.
OK. Try putting in 1st and reverse with the rear end up on jackstands, engine running, no brakes. Rear tires shouldn't turn. If all of that checks out, then there may very well be internal transmission issues.Originally Posted by demelle155
No with the car stopped and running its easy to go in al gears its only when im driving that the grinding occurs (only driven a few test miles).Plastic cap is in place.
3th gen pedals.
Quote:
Ok will check that, thanksOriginally Posted by TransamGTA350
OK. Try putting in 1st and reverse with the rear end up on jackstands, engine running, no brakes. Rear tires shouldn't turn. If all of that checks out, then there may very well be internal transmission issues. jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:94 Times in 91 Posts
eBrake off, Level ground, shifter in 1st gear, pedal down partway,
Can you set the pedal where it doesn't move forward, without putting it to the floor?
And if it to the floor, what happens?
Next time you loosen the slave, inspect the pressure plate for grinding.
Quote:
Well i tested that and the rear tires dont turn.Originally Posted by TransamGTA350
OK. Try putting in 1st and reverse with the rear end up on jackstands, engine running, no brakes. Rear tires shouldn't turn. If all of that checks out, then there may very well be internal transmission issues. Quote:
At 1/4 travel it doesnt move anymore, if i put it to the floor no difference, inspected the pressure plate and no marks of grindingOriginally Posted by jmd
eBrake off, Level ground, shifter in 1st gear, pedal down partway,Can you set the pedal where it doesn't move forward, without putting it to the floor?
Quote:
OK, then I think you have ruled out the clutch. It sounds like there are internal issues within the transmission.Originally Posted by demelle155
Well i tested that and the rear tires dont turn. jmd
close
- Join DateJul 2000
- LocationAridzona
Quote:
your clutch is working as the synchro can match speeds of maindrive (input)/ gearset and synchro hub at 0mph.Originally Posted by demelle155
At 1/4 travel it doesnt move anymore, if i put it to the floor no difference, inspected the pressure plate and no marks of grinding What a synchro cannot do is mesh speed of a mainshaft (output)/driveline/rear with the maindrive at speed. So your input/output have a probable interference situation. Too much bearing preload can cause this. The T56 bearing set is robust and does not commonly just "wear out and need replacement." Yours warrant cone/cup inspection, a re-set of bearing preload/endplay (the original Borg Warner manual or early 90s GM Helms 4th gen service manual specs.) at a mimimum, plus overall internal inspection.
