700R4 Re-seal
700R4 Re-seal
Hi guys, about eight years ago I bought a freshly rebuilt 700R4 for my '88 Trans-Am on this site. Well because of medical issues the trans along with the rest of the car has sat in the garage during that time. My question is, do you guys think I should take it to a trans. shop to be checked out and possibly resealed before I install it? Thanks for any opinions, Ron.
Re: 700R4 Re-seal
Not unless you think something might have happened to it along the way, like, if it was improperly stored, such as where water could get into it.
There's not really any such thing.
resealed
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: 700R4 Re-seal
Being it was stored in the garage. I think it should be ok, at least no worse than it was when you bought it. But if you stored it with the torque converter installed, then you should at-least replace the front seal. The last time I asked a local shop to re-seal a trans, I got the deer-in-the-headlights-look and they did that same job about 10 years earlier on another car of mine. I think it may be hard to find a shop willing to do a re-seal without charging you for a complete re-build. The reason for this I believe is because for both jobs the trans has to be removed. As a minimum, the trans has to be removed to replace the front seal. I think the other seals can be replaced with the trans in the car.
Good Luck,
Fred
Good Luck,
Fred
Re: 700R4 Re-seal
In general, a transmission shop won't TOUCH a transmission without rebuilding it, because if they do, then ANYTHING that happens afterwards, FOREVER, becomes automatically their fault, according to the customer. They're gonna get their pound of flesh outta ya before taking that on.
Seals don't go bad from sitting around, either before they're installed, or after. Butt hay, if you want to futz around with it for whyever, it's yours, go on ahead. I think you'd be wasting your time and risking making it worse than however it is now butt that's just MO.
Car: 1985 Z28
Engine: 305 LG4
Re: 700R4 Re-seal
Seals can go bad from sitting around, depending largely on the quality of the seal and a few other factors. I would put in a new front seal and install the transmission. Anything else that might turn out to be leaking can be replaced pretty easy while in the car if needed.
Re: 700R4 Re-seal
Hi guys, thanks for the opinions. The converter has been off the trans. since I bought it, with the opening sealed up with duct tape. I'll take a close look at the front and rear seals, if they look good I'll probably take a chance and put the trans. in. On the other hand it wouldn't hurt to call a local trans. shop and see if they will change just those two seals. Thanks again, Ron.
Transmission: 2004r
Re: 700R4 Re-seal
Good Luck,
Fred
Car: '89 GTA
Engine: ZZ6TPI
Re: 700R4 Re-seal
Car: 1984 Trans AM
Transmission: 700-4r
Re: 700R4 Re-seal
A trans shop experienced in working on these transmission could replace the front seals, pump seals & rear seals
I that done on a TH350 during restoration of my 1972 Buick GS.
lethaldomestics
Nov 22, 2011 11:12 AM
jmiller
Nov 4, 2009 02:33 PM
