TIMKEN SET9
Old Nov 7, 2025 | 08:54 AM
87gtaredonred's Avatar
TIMKEN SET9
Ok guys, I posted about a week ago I was confused on my axle seals I needed for my bearings. I think I finally got that sorted thank god. My question now is which way does the actually bearing go Ive seen videos and read so much Im so confused. Ive seen them go in both ways some say it doesn't matter some say it does LOL. Im going crazy quick lol. Can any of you guys be of any help. Thanks in advance as always!!!
Old Nov 7, 2025 | 10:52 AM
Bald_eagle_machine's Avatar
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Re: TIMKEN SET9
I need to pull my axles to switch my backing plates, so I will need to do my seals and bearings soon as well. Following in case anyone has any input.
Old Nov 7, 2025 | 01:24 PM
Re: TIMKEN SET9
Not sure how it could possibly "doesn't matter".
The race ends up in the bore of the housing, facing the way that the cone can go into it (large inner dia outward; and the cone goes on the shaft facing the way that it can go into the race (small end facing inward).
Look at the photo in post #14 of this https://www.thirdgen.org/forums/tran...oc-3-23-a.html.
Old Nov 7, 2025 | 02:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TIMKEN SET9
10 bolt or 9 ?
assuming it’s a 9, what sofa said
Old Nov 7, 2025 | 02:41 PM
Re: TIMKEN SET9
Its a 9 bolt, 87 GTA
Old Nov 7, 2025 | 02:44 PM
Re: TIMKEN SET9
The set9 is a 1 piece bearing, just to look at it both ends look the same size. I guess I need to find my calibers to be for sure. The pic on post 14 is the original bearing yea I see what your saying on that one.
Old Nov 7, 2025 | 05:05 PM
Re: TIMKEN SET9
Set 9 is a 2-piece bearing. An outer race, and a cone assy of the inner race and cage w rollers. Very typical and ordinary trailer axle, wheel, etc. bearing.
Yellow92RS
Mar 14, 2023 10:26 AM
h1-vltg
Aug 10, 2007 10:40 PM
Gladstoneiroc
Apr 16, 2006 11:43 PM
LaxStreetRacer
South East Region
May 9, 2005 11:28 PM
FormulaGod
Jul 5, 2002 01:30 PM
