Full Clarification, 4th gen pedals and clutch master
Old Jan 19, 2026 | 08:58 AM
3rdGenReboot's Avatar
Hello all,
I am working on my 85 Bird. I have 4th gen pedals installed already. I plan on running a hydraulic throwout bearing with whatever trans I install- likely not a T56. I have scoured the forums and here is what is clear to me (seems to be)
- with 4th gen pedals and 3rd gen hydraulics, you have to get an adjustable master cylinder, make an adjustable rod, or move the pedal pivot point.
My simple question: If I have 4th gen pedals, can I run a 4th gen master cylinder without modification to the pedals and get the correct pivot/travel?
Additionally, it appeared that this could work as well from the thread where an adjustable bracket was made.
http://www.tickperformance.com/tick-...or-ls1-f-body/
Thanks in advance.
Old Jan 19, 2026 | 09:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Full Clarification, 4th gen pedals and clutch master
Yes.
Correct.
Aftermarket CSC producers typically reference a given bore and travel needed at the master cylinder. Be familiar with yours as you move towards the mix n match game.
Old Jan 20, 2026 | 05:54 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I had bought 4th gen pedals and master. IMO, they sucked and I hated the pedal height. I went with Hawks adjustable slave/master setup and couldn't be happier.
Old Jan 22, 2026 | 08:02 AM
Thanks again all. Helpful.
H4lucinati0ns
Brakes
Nov 20, 2024 02:59 PM
Duke901
Feb 9, 2014 01:01 PM
Garrett Ross
May 14, 2012 11:06 PM
89JunkerRS
May 5, 2012 06:38 PM
