tranny slipping when i turn?
Old Jan 30, 2002 | 11:57 AM
mattRS's Avatar
this has only started happening recently. on right turns, it feels like my tranny (700R4) is slipping a little. it revs higher without me speeding up. problem or my imagination? car only has 85K on it, its an 89 RS
Old Jan 30, 2002 | 12:19 PM
jdrobley's Avatar
did you check your fluid level? the turn can cause the fluid to go to one side and be below the pickup. the trans should be warm wen you check it and shift it through the gears just before you check it. if it is low, make sure it isn't burnt.
Old Jan 30, 2002 | 03:16 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
also, check that tranny fluid with the car idling hot.
you sure you aren't just spinning the inside rear tire?
Old Jan 30, 2002 | 07:08 PM
Jay 727's Avatar
I had this on a th350 (same governor as 700) transfixleo recommended checking the governor cover to make sure it was on tight, if it's loose it may cause too much gov end play during a right hand turn or, in my case, a bump. If this isn't it pull the pan down and look for a filter problem. Be sure first the fluid level is correct.
Old Jan 30, 2002 | 07:27 PM
mattRS's Avatar
yeah, i dont think that the tire is spinning b/c when i take the turn, it revs up higher, but then it drops and there is no difference in the speed i was traveling(if that made sense). i mean, i can feel it grip. when the RPMs go back down i would be able to feel the tire catch if it was that, i think. plus, its a brand new tire and din't start until recently. im going to try the fluid tomorrow. thanks guys. oh, where is the governor cover?
Old Jan 30, 2002 | 07:49 PM
Jay 727's Avatar
It's the round cover on the drivers side of the trans towards the back. I don't see how it would come loose but it's an easy check, just run your fingernail around the cover to be sure there is no gap between the lip of the cover and the trans case.
Old Jan 31, 2002 | 03:59 AM
transfixleo's Avatar
Even if the level checks OK, and I think it will be low, try adding upwards of a quart of oil and see if it is fixed. It wouldn't be the first time a wrong/inacurate stick was in a tranny.
Old Jan 31, 2002 | 09:13 AM
mattRS's Avatar
yup, my buddy checked it last nihgt while i was changing hie fuel filter(how does that work!?)and it was really low...don't know why i didnt just try that in the first place!!! thanks guys
Street Lethal
Apr 30, 2019 12:14 PM
Warlocksirix
Sep 3, 2015 12:26 PM
WIzmo
Aug 30, 2015 02:30 PM
someone972
Aug 30, 2015 12:52 AM
spaigo
Aug 21, 2015 07:46 PM
