Clutch problem?
Old Feb 1, 2002 | 12:58 PM
TA76's Avatar
Clutch problem?
I have an 83 TA with a T5 manual tranny. When I ease out on the clutch in 1st or reverse I feel a vibration... kinda shudders. If I release the clutch a little more quickly no vibration. So, do I have a new clutch in my near future?
Thanks!
Old Feb 1, 2002 | 07:52 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
are u giving it any gas? the car will shake rigth be4 its about to stall. give it a little more gas when u are takin off and it shouldn't shake.
Old Feb 1, 2002 | 08:50 PM
TA76's Avatar
Yep, I'm giving it gas.
Old Feb 1, 2002 | 10:28 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Sounds like clutch chatter (at least that is what I call it).Its the same thing as a brake rotor that gets a hot spot in it and gives you that shaky steering wheel shudder.Could be caused by many things,oil leaking from rear main onto clutch,out of whack linkage,clutch slipping slightly causing it to over heat the flywheel,the list goes on.Not necessarily meaning time for a new clutch if you can live with the shudder.If it isn't to bad I would keep driving it,at least that is what I did till I built my new motor and swapped it out.
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
