something bad just happened, help please
Old Feb 1, 2002 | 09:11 PM
silentneko's Avatar
hey guys
I drove home a few min ago, and when I pulled up I put my car in park and it just rolled back, and if I touch it lightly it pops into reverse. park is just like neutral now and I have to use my e-brake to park my car. whats wrong, please help me my car is my only transportation. thank you.
Old Feb 1, 2002 | 10:20 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Sounds like your shift linkage is out of whack where it hooks up to the tranny itself.Jack it up (use jack stands!!!) and see if it goes into the gear it should be in when the shifter is in that gear.Having a friend shift thru the gears while you are underneath will help alot.If that is not it,it sounds like it could be an internal problem,and in that case I have no clue,I run manuals myself.Hope this helps you out some.
Old Feb 2, 2002 | 01:20 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
like onebadz said it could be that your linkage is out of whack or it could be like something that happened to me. on my 86' the bolts that hold the shift linkage at the tranny came loose and allowing excessive play. so reverse was park and neutral was od etc.... best of luck.
Old Feb 2, 2002 | 02:25 AM
Jza's Avatar
Jza
I'd check the lever on the transmission where the cable attaches. A long time ago, the nut spun off the stub and the lever got cockeyed, so it did exactly what you described when I stopped in the driveway.
Old Feb 2, 2002 | 08:26 AM
silentneko's Avatar
thanks guys
so if I jack the car up I can get to the pretty easily right, should I also take my console apart and look from up there.
Old Feb 2, 2002 | 12:10 PM
silentneko's Avatar
or do I have to drop the tranny.
Old Feb 2, 2002 | 01:26 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Yeah it's easy to get to. Just jack it up in the front and put it on jackstands. The linkage is on the drivers side of the tranny. Remeber to put bricks or something behind your tires too, theres nothing more important than safty.
-Matt
Old Feb 3, 2002 | 12:21 AM
Jza's Avatar
Jza
Under the car, on the driver's side of the transmission pan, you'll see where the cable meets the lever. DEFINITELY block the wheels, 'cause if you fiddle with that lever, knock it into neutral or even reverse on a sloped driveway while you're under it..... Before I lowered mine, I used to be able to get away with just parking over the dip in the driveway or putting the front wheels up into a curb just for a quick peek under the car.
Old Feb 3, 2002 | 05:46 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
in an automatic trans there is a little peice of metel that pops out and goes in between some teeth to put a car in park. its a real dinky set up and they can break real easy. so if wut these guys are tellin ya isn't the prob then its probably this.
Old Feb 4, 2002 | 07:15 AM
silentneko's Avatar
thanks guys, it turned out that the bolts that hold the shifter cable to the tranny pan fell out, I put new ones in and it seems ok.:hail:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Gunsbee
Sep 7, 2015 07:10 PM
SG91camaro
Sep 5, 2015 10:27 PM
