w-c t-5
Old Feb 5, 2002 | 09:10 PM
js 84 z-28's Avatar
w-c t-5
what year did the world class t-5 tranny get put in. I am looking to buy a t-5 from a 89 iroc. How can I tell if it is a w-c or not
Old Feb 5, 2002 | 11:29 PM
David 91RS/Z28's Avatar
The input shaft bearing should say timken on it.
Old Feb 6, 2002 | 01:55 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All 88-92 thirdgens with manual transmissions are World Class T5's. Unless someone else swapped in a non-world class, of course. There's a partial VIN on the passenger side, I think the 2nd digit would be J,K,L,M,or N representing years 88 to 92. Also the front of the trans has a large circle, partially covered by the input shaft cover. Thats what David is referring to. It will say TIMKIN along its circumference.
Old Feb 7, 2002 | 04:53 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My non-world class had a Timkin bearing on it too. I purchased a bearing for a 91 WC, and it was exactly the same as the Timkin I took off of the non WC unit.
Old Feb 7, 2002 | 05:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.5speeds.com/
Old Feb 12, 2002 | 07:38 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
i have an 89 formula does this mean i have the world class tranny? also if i do what are the spec on it like how much better it then the normal t-5. how much torqe can it handle
Old Feb 12, 2002 | 10:33 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
300 ft lbs. Still not enough for a decent motor.
Old Feb 13, 2002 | 08:48 AM
Car: 89 Formula
Engine: Carbed 5.7
but i thought the nomal t-5 was ratef at 310
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
