Holley and 700r4, what should be the proper TV angle?
Old Feb 14, 2002 | 01:12 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Im not willing to but a $50 bracket to fix the alignment problem with a Holley carb (700r4 tranny) its a little overpriced considering I can bend the bracket for free
What should be the proper angle? Im using the bottem hole on the carb for the TV. Should the cable be set to perfectly straight ------, or will a slight angle be good enough?
Thanks!
And yes I asked around the carb board.
Old Feb 14, 2002 | 08:06 PM
MR.HP's Avatar
From what I understand it is 1.125 from center of shaft , on clock from 5:00 to 7:00 { No Flame} But I notice Pro-Built jump right over your ? I even bought a trans from him NO problems,But He here to SELL Only anymore.
Dale
Old Feb 14, 2002 | 10:14 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thanks for the reply. So it should be set fairly straight.
Thanks!
Old Feb 14, 2002 | 11:48 PM
Pro Built Automatics's Avatar
The distance from the center of the throttle blade to the center of the TV cable hole is 1.11". The TV cable should start at the 4:45 postion & wind up at 7:15 in the WOT position. The center of the clock being the throttle blade. Most late Holley's & Edelbrock carbs are setup with the TV hole being close to right.
Old Feb 15, 2002 | 12:45 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<img src="http://members.home.com/crussel/tv_geometry.jpg">
Old Feb 15, 2002 | 10:32 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thanks guys! That will help alot!!!!!
Thanks again
Old Feb 15, 2002 | 01:58 PM
Jay 727's Avatar
I used the diagram above, cut a V in the linkage, bent it, checked it, rechecked it and welded it up. It's a pain in the ***. I have seen the brackets for $30 Summit even carries them now, I'd rather just buy one.
I used a clear protractor and carb stand to take measurments.
Old Feb 21, 2002 | 09:43 PM
jayman350's Avatar
I bought the bracket thats in summit and it works great. when you look at it it looks like it might be off, until you pull the throttle back and the cable goes completely straight.
I say spend the $$ and not have to worry about it, my holley was brand new and it wasn't even close to being in the right position
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Magman
Sep 14, 2015 01:30 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
