4th gen t-5
Old Feb 21, 2002 | 11:17 PM
chooch-88formula's Avatar
4th gen t-5
if I put a 4th gen t-5 in and 88 formula would I have to use the t-56 custom crossmember? or can I use the stock 88 crossmember?
thanks,
Old Feb 22, 2002 | 12:01 AM
87RS402's Avatar
4th gen T-5?
Do you want the good news or the bad news?
Old Feb 22, 2002 | 12:07 AM
I'll take door # 1 and door # 2.
(both please)
I was going to buy this tomarrow (friday)
Old Feb 22, 2002 | 12:36 AM
87RS402's Avatar
Bad news: The T-5 wasn't available in the 4th gen to my knowledge.
Good news: If it was it's a WC T-5.
Bad news: It's nothing special.
Old Feb 22, 2002 | 12:44 AM
oddly enough it is a t5... they were avalible of all years. the 4th gen has an rpo code of M49.... The only thing special about this tranny is ... it's close to me, not high milage, and at a decent price.
but basically I was wondering what the bolt pattern is? is it like a third gen t5 or like the t56? (crossmember bolt pattern that is)
Old Feb 22, 2002 | 05:24 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I though the 5 speed was only available with the six cylinder...If so then the bellhousing and clutch assembly may be different.
Old Feb 22, 2002 | 09:22 AM
I think your right... the junk yard must of had it wrong in thier computer.... they are now going out to the car to verifiy what is in it....
Old Feb 22, 2002 | 01:28 PM
u r sofa king we tah did's Avatar
he is right, its from a 60 degree V6, only transmissions from a 90 degree V6 (ie. 4.3L) will work on a V8
Old Feb 22, 2002 | 03:36 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
what about the 3800 V6? that's a 90 degree V6, unlike the earlier 3.4 liters.
Old Feb 22, 2002 | 03:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The trans itelf doesn't care about which 6-cyl it came from, only the bell housing is different. The trans itself is the same no matter which 6-cyl it was behind.
However, a 6-cyl trans has different splines where it plugs into the clutch from what a V8 one has. You could theoretically make it work by using a 6-cyl clutch disk. I doubt it would be a good match though; you would hate the gears (very wide ratios) and probaby burn up the clutch because it's a good bit smaller than the already too-small V8 clutch disc.
Warlocksirix
Sep 3, 2015 12:26 PM
Cacike
Aug 27, 2015 05:10 PM
cam-mike
Aug 24, 2015 07:23 AM
