Pink sauce and tranny mounts :D
Old Mar 11, 2002 | 09:28 PM
tpi_roc's Avatar
Hello trans guys
Alright dropped the trans tonight so the car can get on the trailor for a paint job (woohoo!). I just put a new (used) stall in it and drove about 20 miles on it untill an engine melt down. Anywho apon pulling the drive shaft and dumping fluid all over I noticed it was pink! Pink is not good, so im assuming water got in there, now is it likely from
a.) Water in the stall when i put it on?
b.) radiator leaking into trans cooler lines?
Any Idea's? Is there a "C"?
Lastly, Time to put a poly mount in with it when it goes back up, who makes a good one, and who sells one cheap
thanks!
Old Mar 12, 2002 | 03:09 PM
tpi_roc's Avatar
I was told my pepto bismo probably has ruined my clutch plates
any words of encouragement?
Old Mar 13, 2002 | 06:51 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Guess not
Old Mar 13, 2002 | 07:16 PM
tpi_roc's Avatar
Kinda looks that way
not good...
Old Mar 16, 2002 | 12:20 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
One of my friends had "pink sauce" in his trans when he accidently put Type F into his transmission that already was 1/2 full with DexIII. yes it looked like pepto bismol.
Old Mar 16, 2002 | 02:47 AM
86_Dan_Z28's Avatar
Car: 86 Z28
water in tranny
Looks like your radiator cooler is leaking and letting water get into your transmision fluid. You need to bypass the radiator and get a big tranny cooler (like B&Ms) and you need to flush your trans and hopefully it will survive, otherwise you will need a rebuild.
Old Mar 17, 2002 | 04:33 PM
tpi_roc's Avatar
Can anybody else support this? I'd much rather find out there was a mixed fluid in there than water.
Old Mar 17, 2002 | 05:21 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I was told that pink fluid was in fact the cooler was allowing antifreeze to leak inside of itself. not good, also the antifreeze attacks the adhasive that holds the friction material to the metal plates. you might be alright but if it were me I would have the trans rebuilt.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
