Blew ANOTHER 700r4, need help making decision....
Old Mar 26, 2002 | 12:17 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
i blew up another 700R4. The shop is tearing it down right now to fnd out what went wrong. Doesnt sound like it smoked any clutches but there are a lot of metal shavings in the trans pan. There is a possibility if its just a hard part that went bad he may be able to fix the trans. If not or there are way too many problems to fix without a full on rebuild, he says he can have a fresh built turbo 350 installed in car with converter for no more then $900. In the long run probably the best choice. Problem is i drive from here in kalamazoo to chicago about once a month and gas milage is gona suck. Am i fooling myself here trying to make due with a 700r or should I just bite the bullet and put a 350 in knowing it will probably be the easiest (and cheapest) route at this point I really love my overdrive but i cant keep putting trannys in my car. This is the 3rd 700 to blow in 2 years. Wonder how much a t400 would run............
so what would you do in my situation? i am a college student with limited funds and im probalby gona have to borrow cash from my parents. My car is on spray, i want to keep it on spray without blowing up a trans every 4 months. I hopefully will be getting a daily driver before this coming fall. I think the writting is on the wall but I need some help deciding here. thanks
Old Mar 26, 2002 | 01:09 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
hey, i saw your car over in jefferson commons, looks pretty good. There isn't an easy way around having a strong auto with overdrive. a th400 is a three speed so you'll have the same problem as a th350. the 4L80 is an overdrive based on the th400 used in trucks. i don't know if they even fit in our cars though. my ideal idea is a t56 but i know that costs large bucks. i'd build up a strong 700r4 if you can. anyone else done this?
Old Mar 26, 2002 | 01:33 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Get a 700-r4 from www.pro-built.net Thats what I did after going through a couple of other so called performace trannys. No more problems since I have had it, and my car runs on the spray to.
Old Mar 26, 2002 | 01:35 PM
86_Dan_Z28's Avatar
Car: 86 Z28
You don't have to lose overdrive.....
Talk to this guy: http://www.pro-built.net he will build one that won't die on you is a couple years.
Old Mar 26, 2002 | 01:59 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
u guys running the street/strip or the heavy duty???
Old Mar 26, 2002 | 03:30 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
I'm running the street/strip tranny with a 9.5 inch 2800 stall. Both the tranny and the converter are absolutley perfect. I have not had a single problem with them since installing them. Pro-built is a great company to deal with,Dana (the owner) knows his **** about the 700-R4 and spends alot of time with each customer to make sure you are gonna get what you want and the tranny will perform exactly the way you want it. I told him what I wanted and how I wanted it to be and is performs exactly like Dana told me it would. :hail: Pro-built
Old Mar 26, 2002 | 06:28 PM
HulkRacing's Avatar
Row your own!
Old Mar 26, 2002 | 11:25 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
What a great first post!
Anyway, check out Bowtie Overdrives at http://www.700r4.com/sitemap.html they have a number of different levels of 700r4s at really good prices, and I have heard some great things about them.
Read through their site and it seems they have alot of confidence in their work.
I'll be gettin the level 2 as soon as money permits.
Old Mar 27, 2002 | 09:32 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Get the TH350 it will hold up longer and will not break like those unreliable 700r4s
Old Mar 27, 2002 | 10:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Eh; everything I've read and heard seems to say the 700r4 can be made just as reliable as a TH350. It's just harder and more expensive to do! Even the TH350, when it first came out, was deemed as "unreliable", and people dumped the TH350's for Powerglides.
Hell, screw the TH350, wedge a TH400 up there. (just joking)
Old Mar 27, 2002 | 06:06 PM
Bob86ZZ4's Avatar
Go with a th400/Gear Vendors overdrive like I'm doing. You only live once. You can't take it with you. I'm olde money, hahahahahaha.
camaro11j
Sep 19, 2018 08:49 AM
IroczFan
Oct 6, 2015 10:13 AM
masonta
Aug 31, 2015 10:14 PM
dyeager535
Aug 28, 2015 08:10 AM
TreDeClaw
Aug 14, 2015 06:58 PM
