changing tranny fluid
Old Apr 2, 2002 | 05:41 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
i have an 85' Z28 it only has 42K on it and the tranny fluid appears to be fine (bright red) the level is fine too. I just woundering how often you guys change your fluid. If it is fine, i would just assume not mess with it. Transmissions kind of scare me Also, if the car sits most of the time, are there any bad things that can happen to the tranny fluid? The car only is driven regularly 4 months of the year.
Old Apr 2, 2002 | 06:58 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
According to GM you should change it every 30k.
Old Apr 2, 2002 | 07:31 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i change mine every 2000 miles..........call me crazy but my tranny cost me 1500.........and i beat on it
Old Apr 3, 2002 | 10:14 AM
i think i will call you crazy
Old Apr 3, 2002 | 10:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I change it out once a year... fluid/filter/gasket.
Old Apr 3, 2002 | 11:50 AM
sIcK pUpPy's Avatar
I change mine every 7500 or so. Going off memory, , I think that's what the manual calls for.
JD
Old Apr 3, 2002 | 03:23 PM
the car owners manual says.... 100,000 miles, every 30,000 if under heavy use.
as it says 6,000 for oil and 3,000 if under heavy use (i have always done it every 3000.)
the rear axle fluid is the same as the tranny.
even tho i really don't beat on this car at all... i think i will go by the heavy use sugestion.
anyways, im still open to sugestion if you guys have other opinions
Old Apr 3, 2002 | 03:30 PM
Pro Built Automatics's Avatar
If it looks good & smells ok, leave it alone!
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
