How much punishment will a t-5 take?
Old Apr 10, 2002 | 08:36 PM
vscott's Avatar
I have built a 383 stroker that puts out 427hp and 491tq.
I have put it all together and just about ready to start it for the first time, and I have just now thought about my poor trans.
Can any body tell me if this t-5 is going to hold up or am I stupid to even try it.
Old Apr 10, 2002 | 08:57 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
it's too much motor for the tranny but if you take it real easy and avoid any shockloading, it will last awhile. You won't be able to do much high performance driving though.
Old Apr 10, 2002 | 09:49 PM
vscott's Avatar
So it will at least survive engine break in.
Old Apr 10, 2002 | 10:07 PM
xxwarrior36xx's Avatar
Yes it will survive engine break in but I wouldn't expect it to last much more than that. That is alot of power for that trans....start saving for a new one now!
Old Apr 14, 2002 | 01:48 AM
Astro's Avatar
Are you running a t-5 or a world class t-5. If you're running a WC, then you should be alright as long as its in good condition and you dont beat the **** out of it.
Old Apr 14, 2002 | 02:20 AM
Momar's Avatar
I believe even the world class t-5s are only rated at a little over 300. I would say dont powershift definately. I would just kind of take it a bit easy on it until you can afford the new one.
Old Apr 14, 2002 | 08:51 AM
vscott's Avatar
I have found some information on http://www.ttcautomotive.com/
It shows torque ratings for each. And unless the t-56 is underated
I don't believe it will hold up either. Although it will have a much better chance. Has anyone ever tried to build-up a t-5, do they even make better internals for higher performance.
Old Apr 14, 2002 | 10:25 AM
Momar's Avatar
This is not from personal experience, but from what I have heard, if you get a t56 from 94-97 they are strong. I know that some of the fourth gen guys run a lot more through them. I would ask some guys over at www.camaroz28.com if you are thinking about a t56. There are a lot of fourthgen guys over there with a lot of experience with that tranny.
Ben
Old Apr 14, 2002 | 11:53 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i blew my T5 with a V6
food for thought
Old Apr 14, 2002 | 12:14 PM
dvsta's Avatar
we all know you won't be able to keep you foot off it.a tremic 5spd is good but i think the doug nash 5spd is better.we have that behind a small block that was dyno at 449hp with 3:55 gears and that car rocks:rockon:
Old Apr 14, 2002 | 12:25 PM
sIcK pUpPy's Avatar
VSCOTT, The T-56 will take the punishment. Look at what they are run in:
Ram-air Ls1
SS Camaro
Z06s
Viper
Although some internal changes are made for some of these applications, you would be hard pressed to break one. Well, that is unless you're doing 6000rpm launches with slicks .
JD
Old Apr 14, 2002 | 01:04 PM
dvsta's Avatar
the zo6 vette runs a (getrag)trans and doesn't the newer ta's run a richmond 6spd
Old Apr 14, 2002 | 03:02 PM
sIcK pUpPy's Avatar
Not sure, I was going off someone else's expertie on that post. He will be shaved, sterilized, and destroyed . Josh, yer a dead man.
Lates,
JD
Old Apr 14, 2002 | 08:57 PM
Tom84L69's Avatar
Car: 84 Z28
no, Z06 has a T56 but with different ratios.
Old Apr 14, 2002 | 09:29 PM
92superram's Avatar
What about lingenfelter TT vettes, does he do anything to beaf up the T56 before running 650 hp through them?
Old Apr 14, 2002 | 09:47 PM
dvsta's Avatar
a month ago we had a 2001 corvette on the lift and it said getrag on the rear and the trans had ZF on the side of it.but that wasn't a z06.but still probably the same
Old Apr 15, 2002 | 05:55 PM
Silverado5.7L's Avatar
Correct me if I'm wrong, but don't the new vetts run a transaxle?
Old Apr 15, 2002 | 06:13 PM
Tom84L69's Avatar
Car: 84 Z28
the C5s run a transaxle and the t56 is bolted right to the rear differential. A torgues tube with driveshaft runs from the back of the motor to the tans which is bolted to the diff. it's not a getrag, it's made by tremec. the C4 6 speed cars were made by ZF in germany.
Old Apr 15, 2002 | 09:51 PM
92superram's Avatar
That is cool, I never knew that about c5's, i just asumed the trans bolted directly to the engine. That is a great idea, gm engineers deserve a pat on the back for that. I wonder what the F/R weight ratio for c5s.
Old Apr 16, 2002 | 04:22 PM
Tom84L69's Avatar
Car: 84 Z28
i think it still has ~51% on the front wheels, but that's pretty damn good. i bet moving the battery to the rear would solve that! the transaxle idea came from the porsche front engine cars like the 928 and 968 I think.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
