got an accel...
Car: sold the Z now i'm drivin a 81 toyota celica and an 01 Suzuki TL1000R
Engine: 90degree 998cc V twin
Transmission: 6 speed
got an accel...
coil for my car today, i ordered it from work and i'll have it by wed., we're going to the races friday so i'll have it on there for the drag races friday hopefully i'll be able to break into 16's i'll post the times saturday!! i can't wait anyone have any tips i should know about??
wish me luck!!
wish me luck!!
not sure to be exzact, i work at a zone so i just ordered the one we have listed under my car
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
could that be A-zone? the one I work at has MSD stuff in stock, will be getting 2 for the blazer/bird. will either get the accel or msd for the boat. 20% discount really adds up don't it? :lala:
Mine is hung (isn't everyones?????)
on the passenger area, firewall over hang.
I have no coil in the stock brcket location.
I made a "L" bracket, hung coil upside down attached to bracket.
Others say it's not recommended to hang upside down.
I've had not a single problem.
It will HELP, it is not a total cure.
But, it cure will hlep.
You'll hardly notice the subtle difference, but, it's a good choice!
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I found an Accel Direct fit Coil at Pepboys for GM Cars. Bolted perfectly in. I don't know the specs on it though, but it sure is better than My old one!
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
what is the advantage of mounting it away from the stock position besides all the heat from exhuast manifold? Or is that the only one? How much damage will the heat cuase?
Heat leads to premature failure.
Always keep auto electronics away from engine/sun heat.
MANY drag racers actually have fans blowing on their in-car ignition boxes.
Can you say:
"heat soaked starter woes"
Can you say:
To the guys that shop at Pep Boys. Please shop elsewhere. They have a REALLY BAD rep with customer service. link for details. They have a bad rep for refusing to fix WHAT THEY SCREWED UP. Even look at the vendor boards on THIS site for problems. If you can live without for a couple days, do the mail oder. PLEASE.
http://www.planetfeedback.com/share...te-desc,00.html
Can you say:
Can you say:
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
As for the Coil Mounting...how would I go about relocating it?
I made an "L" Bracket.
I hung it frm, that area, upside down.
It fits fine and the wire is close to needed energy source.
Give it a shot, by holding it there with your hand, upside down, wire hooked to distb.
It's one option that worked for me.
Made bracket from "thick" aluminum, easy bend, absorbs vibrations
20% discount
yeah thats A-zone only problem is i can't get 20% off of the express ordered parts, we have MSD stuff in stock, some accel but not the coil i ordered.
