Accessory fuse blows...
Old Apr 18, 2002 | 11:49 PM
Akshay's Avatar
The Accessories fuse blows. I know that there's a short.
But where do I look? All I know is that the wire is orange.
There are tons of other orange wires.
All the wires are in black plastic flexible coil thingy (makes it very hard to trace the one, of many, orange wire).
The following don't work, cigar lighter, map/courtesy light, and stereo (won't work on ACC postion).
Is this because the Accessory fuse is blown?
Akshay
1989 2.8 5-spd.
Old Apr 19, 2002 | 11:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Accessory fuse blows...
Akshay
1989 2.8 5-spd.
It's the cigar lighter. Pull it out, put in console, replace fuse.
RBob.
Old Apr 19, 2002 | 12:16 PM
Akshay's Avatar
Re: Re: Accessory fuse blows...
RBob.
So, I should pull the cigar lighter out, and then put it back in?
I don't understand what you mean by, "put in console".
Akshay
Old Apr 19, 2002 | 06:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think he means to put the "push-in lighter" into the console, to keep it out of the lighter socket.
Do you keep change in the ashtray? Try looking in the lighter socket for a penny.
Old Apr 19, 2002 | 08:19 PM
Akshay's Avatar
I think I have the Fuse Block for 1990-1992 model Camaro.
That's why I have a 20amp ACC (Accessory) fuse, whereas, 1985-1989 Camaro Fuse Blocks have a 20amp CTSY (Courtesy) fuse instead.
But the wiring should be somewhat similar. (I hope)
Am I right?
Akshay
1989 2.8 5-spd.
Old Apr 19, 2002 | 08:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yelp, the cigar lighter body shorts to the
shell. Took me forever to figure out what was
causing the fuse to blow.
I started to use a scan tool alot then went
and put the lighter back in. With that the fuse
started to pop again. Hmmm, took the lighter out,
dropped it into the console, and the fuse didn't
blow again until I put the lighter back.
That time I noticed sparking in between the
lighter body and shell. Lighter's back in the console. Fuse has been good for over 2 years
since.
RBob.
'92 RS
Old Apr 25, 2002 | 02:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So; still got a short? What happened?
Old Apr 25, 2002 | 03:43 PM
Akshay's Avatar
Yup, I haven't had the time to fix the short. I will, however, track the ground wire and see if it's okay.
I know that the cigar lighter is connected to the dome or courtesy light (don't remember which one), which then are grounded.
The repair manual says that the cigar lighter is connected the glove box light, and both are grounded.
Since these cars don't have a glove box (it blows my mind), I guess I'm screwed for the time-being.
(I can't believe 3rd gen. camaro's don't have a glove box).
Akshay
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
