tachometer
Old May 1, 2002 | 03:49 PM
aaroedg's Avatar
tachometer
What does a 2.8L redline at? i want to buy a tach, so what should i get it to go up to, 6000?
Old May 1, 2002 | 04:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
6k should be good. I don't think I've ever gone above 5500. My Sunpro tach swings (if I recall correctly) to 8000 rpm.
Old May 1, 2002 | 05:58 PM
Xenodrgn's Avatar
Mine will tac up to 8 as well, and I have the red indicator set at 5200. The tranny shifts the engine at 5K.
Old May 1, 2002 | 09:33 PM
aaroedg's Avatar
thanks
Old May 1, 2002 | 09:44 PM
phix919's Avatar
hmm, so which wire does the tach hook up to? arggg too many wires
Old May 1, 2002 | 10:56 PM
GhostRider84's Avatar
Check the Chilton's manual - it shows the tach hooking to the pink wire from the distributor (notthe pink wire from the wiring harness). Looks to me, if you have CrossFire Ing. a regular tach ain't gona work.
Old May 1, 2002 | 11:06 PM
5.0 10's Avatar
you hook the tach to the white wire that is in the same plug as a pink wire on your coil. The pink wire powers the coil and the white wire is the tach signal.
Old May 2, 2002 | 09:46 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually, it's a black/white wire (on the gray connector), but, same thing. Think twice before using the blue splice connector to tap into the wire. My splice connector wound up cutting thru 99% of the copper strands in that black/white wire, and almost left me stranded.
To fix it, I cut the harness wire in half, and stripped back the insulation on both sides. I crimped a non-insulated butt terminal over one end of the harness wire. Then I twisted the tach wire with the remaining harness wire end, and crimped the two into the butt connector. Then I added solder to the ends, and taped it all up.
'Course you could just peel back a bit of the insulation and twist the tach wire onto the harness wire and then solder/tape the joint...
What kind of tachometer did you buy?
Old Aug 12, 2004 | 02:39 PM
5.0 10's Avatar
The white wire only goes to the tach so you can just cut it and add your new wire. Cutting it will not leave you stranded.
Old Aug 12, 2004 | 08:42 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
My car has seen 8000 rpm one for a micro second by mistake
toones
Jan 6, 2016 06:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
99Hawk120
Mar 13, 2002 02:24 PM
