What are you V6 guys runnin in the 1/4?
Old May 12, 2002 | 03:14 PM
85_ZED28's Avatar
Car: '85 Z28
Just curious, I'm not going to flame or anyting, I love all F-Bodies
Old May 12, 2002 | 08:32 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
stock, V6's EFI 3rd gens are about 17 second flat cars
Old May 13, 2002 | 09:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
1996, no mods, poorly running engine- 16.87
2001, modded a lot, engine running great- 17.4
It's gotta be the mileage (+200,000 miles)!
Old May 13, 2002 | 02:52 PM
89camaroRSV6's Avatar
some time ago i gteched mine and ran a 16's
once i ran a 15.9 that was stripped out car...
now that teh 19lb injectors are in im gonna be runnning the car soon...i would love to run it in a drag strip ...
(actually im running lean with the 19# injectors and im still figuring out why....)
Old May 15, 2002 | 02:04 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
In sig.
Old May 15, 2002 | 04:16 PM
Setzer's Avatar
Also in the sig!!!
Old May 15, 2002 | 11:46 PM
85CamaroRulz's Avatar
15.91 seconds at the local track
Old May 16, 2002 | 12:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
On which motor? Aren't you on your third 2.8? Let's see your timeslip.
Old May 16, 2002 | 09:30 PM
Yea this is my third motor, the 2nd motor, I got ****ed on that deal, The cam was shot, My "friend" sold it to me. That time was about a month ago and I didn't keep the timeslip, Next month I go again, I will give one to you then
Old May 16, 2002 | 11:05 PM
DRKTEALV6BRD's Avatar
9.04@155 MPH 1/4 mile with a blindfold on and a lead foot
Old May 17, 2002 | 12:15 AM
was that ur car being towed by a top fuel dragster..?????
across the finish line...
or maybe he was pushing ya...
Old May 17, 2002 | 12:52 AM
nah the tires lit up and i flew down the track like a bat out of hell and did it. All i needed wuz my lead foot and my batmobile exhaust.
Old May 17, 2002 | 01:03 AM
the batmobile has a jet engine ....not just an exhaust...come on man get real...whats ur real ET..85Zed just wants to know ....
Old May 17, 2002 | 05:57 AM
thats pretty good for a V6
Old May 17, 2002 | 11:05 AM
86camarodriver's Avatar
Well I have an 86 camaro, A/C delete, rear seat delete, smog delete, spare tire and jack delete (for the track), autolite plugs, new wires (crap), blue streak cap and rotor, accel super coil, gutted catt converter, better flowing Y-pipe, gutted air boxes and air lid, cleaned out TB and MAF, I also took off the steel wheels and put on Z-28 aluminum wheels, along with a 700 r4 and some descent gears. With that and a few problems still I have a 0-60 time of 8 seconds and my head gaskets just went out so I am going to replace those and port the intake and heads and put a flowmaster muffler on and I hope to run a 16. I also have NO power options at all, no GFX no nothin
David
Old May 17, 2002 | 04:16 PM
ohh come on 85camaroRulz....
i have alot of mods in my car and i run 15.9
my mods in my sig...
i see u running the same ...this is not to flame or anything but what mods are u runnign to make that time..
i still have to run after the 19lbs went in
Old May 17, 2002 | 11:22 PM
CamaroChick's Avatar
Am i the only one who has V6 anguish?? The amount of money put into a V6 to get it into the 13's can be put into a V8 and make it go 11's... its a waste of $$ to fix a V6 up... just go for a big block! If someone can argue, please do.. change my mind about my dinky little V6 that is pushing high 16's...
Old May 18, 2002 | 12:46 AM
You are right HOWEVER for a few grand you can make a 383 small block on a high 10 with nitrous. Big blocks take a lot of work to get in and suck up a lot of gas just going around ten and I will be happy with my low 11 high 10 on a good day when I get my 383 built up. ALSO I have a beautiful artic white 86 sport coupe with a 2.8 and a auto tranny and 3.42 gears and they all have 135k miles. Untill yesterday I was runing a 0-60 time of 8 seconds flat and the right lower brake shoe is not adjusted right so part of it is touching the brake drum 24/7, the MAF was going bad along with the head gaskets and they just let loose yesderday and that was quite scary, I also have a cold air sensow that is going bad. I took the steel wheels off and added aluminum Z-28 wheels, pulled the A/C, smog pulled, pulled the rear seats, and the spare and the jack, I also have NO power options, no GFX and no fog lights, so with those problems I was going that fast, not bad ehh? When it comes to mods I have autolite plugs, crapy wires, blue streak cap and rotor, accel super coil, high flow y-pipe, gutted cat converter, gutted air boxes and air lid. All in all this cost me 100 for the wheels and 50 bucks for the ignitions and the gutted catt and y-pipe where free.
Soon the car will have the insulation under the carpet pulled, a fiperglass hood put on and a aluminum radiator, this will get me right at the 3,000 pound mark and will be mods for the 383 also.
In a few weeks the intake plenium will be completley ported and polished for free and for the new 3.4 and I will have a 3.4 v-6 that will get a crane cam, and ported heads (free) and that will all in all cost me ohh $500 and I can use the same tranny and exhaust and everything hooks up. With this set up I will have around a grand invested and be runing a mid to low 15 second quarter mile and the hood and radiator will me considerd 383 mods. Also the 2000 camaro with the 3.8 v-6, auto tranny, air lid, flowmaster and msd wires runs the quarter in 15.2 YOU DO THE MATH, if you play with the shift points it will tap into the high 14 range. Here I am I got a car for 15 hundered and invested a grand and taped into the mid 15's when a 2000 and newer camaro v-6 runs only a half second beter.
David
P.S. In most camaro clubs 13's are considered slow and they are laughed at, 11's are fast.
16's are easy with a 2.8 I did it with a meesly 50 bucks.
Also with some NOS you can get a 3.8 into the 13's easy.
Why go big block when you can make a FI 383 go LOW 11 high ten with a few grand. My 2.8 right now beats up on 3.1's all the time and I have beaten my buddy in his TBI 4.3 v-6 even though its a POS
You can also get a 4.3 to run 13 second quarter miles pretty cheap
The 1994 Porsche 911 turbo runs a 11.8 from the factory and its a 6 banger, the rest of the porsches are 4 bangers and they will eat most cars for lunch, the only thing that matters is how much air and fuel you can get in the cylinders.
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
tricky1
Aug 23, 2015 01:17 PM
Street Lethal
Aug 14, 2015 08:25 PM
