CAI Inspection...
Old May 13, 2002 | 07:31 PM
RealDeal's Avatar
CAI Inspection...
Ok, after about an hour of planning and actual underhood work, and two trips to home depot, i finished my cold air intake. it's amazing the sound difference.... just so nice to hear the sucking sound. i still want to paint the pvc pipe black, so it doesn't look as tacky, but i also will get some pictures up so the rest of you can critique my work
i only have one question though. will i have to worry about passing inspection with this thing? i never really contemplated it.... i have the old set up, i was just curious if it would be questioned, or if the mechanics will just see that it's custom and move on?
Old May 14, 2002 | 09:00 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Depends on how picky your mechanics are; do they need to pop the hood? I put my stock intake on just to pass inspection... I didn't go to a state center, but I figured I might as well do it anyway.
Old May 14, 2002 | 04:18 PM
KED85's Avatar
At Smog inspection time, ALWAYS REINSTALL YOUR CORRECT ENGINE SMOG PARTS.
Unless they have smog ok tags on them.
Old May 14, 2002 | 06:02 PM
RealDeal's Avatar
alright... i don't have to worry about that for a couple months and its as easy as loosening the fastener, so that's alright... thanks
Old May 14, 2002 | 07:22 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I guess i need to find a stock intake for my car now lol i got mad and thrw a wrench and it happend to hit the intake and brake it lol. Any one wnat to sell one for a 3.1?
Old May 15, 2002 | 09:15 AM
KED85's Avatar
David,
Remove it & I can get it welded.
Old May 15, 2002 | 07:16 PM
FAST RS's Avatar
Oh i was tlaking about the stock pice not the CAI i have in right now i there is a plastc pice that goes form tie throtlebody to the air cleaner assembly i got mad threw my wrench bounced off the floor hit the plastic pice and broke it apart lol
Old May 16, 2002 | 11:25 PM
maverick544's Avatar
dont worry about they wont car unless u got a carbed car
Old May 17, 2002 | 09:28 AM
KED85's Avatar
Why waste your time failing.
IF ya live in CA it's a sure thing that they'll fail ya, real quick.
Old May 17, 2002 | 02:27 PM
FAST RS's Avatar
Ill probl just go to my friends shop hes pretty leanient on stuff like that he even said if i ever put a V8 in my car hed still pass my smog all id have to do is bring a frined witha 2.8 or 3.1 and smog his car as mine . But im still ognna be lookin for that part.
Old May 17, 2002 | 04:51 PM
RealDeal's Avatar
I know this thread kinda got off topic, but whatever helps whoever needs it, right? here are the pictures as promised... tell me what you think.
Old May 17, 2002 | 04:52 PM
RealDeal's Avatar
Old May 17, 2002 | 04:54 PM
RealDeal's Avatar
last one:
Old May 17, 2002 | 07:48 PM
FAST RS's Avatar
Looks almost like mine if i were you id move the charcole cnister more tords the front and have the air filter in oyur wheel well thats were i put mine.
Old May 18, 2002 | 10:13 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Question: Did you guys or anyone ever get a Y connecter and make a dual CAI?
Old May 18, 2002 | 11:41 AM
KED85's Avatar
Here's what ya do with yours.
Make TEMPLATE of cardboard, to box off the "hot air" from the engine bay.
Get plexiglass cut to duplicate the cardboard template.
Install it.
NEXT, from below bumper, get a hose to throw cool air off ground to your air filter.
Curve hose thru the inner fender area.
All you're sucking in is hot engine bay air.
Old May 18, 2002 | 12:53 PM
Or cut a piece of sheet metal to fit than cover it in high temp paint, thats what I did.
Old May 18, 2002 | 02:24 PM
92Blue3.1's Avatar
should i stick with my TPI dual snorkel with the bottom box cut off and 2 K&N's or.. should i make a custom PVC intake with a conical air filter? what should i do?
Old May 18, 2002 | 02:28 PM
FAST RS's Avatar
I like the CAI i had the z28 doulsnorkel intake and it worked great but i noticed it was bringing hot air into my engine becasue it sits on top of the radiator and all that heat goes into it makeing hot air. So i went back to the CAI
Old May 18, 2002 | 02:42 PM
I've heard of people using a heat resistant blanket of some sort over the radiator to keep the air cool.
Old May 24, 2002 | 12:59 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I never got any problems with my intake. I have the CAI from SLP. It looks stock...
Old May 25, 2002 | 12:42 AM
AFrikinGoodTime's Avatar
how well does you cars run without the MAF sensor? Don't you show a computer code and run in open loop?
Old May 25, 2002 | 01:12 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
3.1L v6's don't use a MAF sensor, reason they can run a cold air intake without the "difficulty" of relocating the Mass Air Flow. That's the only thing that makes CAI about eh....1/1000 more difficult for 2.8L people that it is for 3.1L folks.
Old May 25, 2002 | 01:15 AM
That answers that question. Thank you.
crazyjoe
Jan 7, 2003 09:11 PM
Zepher
May 15, 2002 09:48 PM
SillyWabbit
Nov 17, 2001 10:55 PM
Zepher
Nov 15, 2001 11:51 PM
3.1EyeCandy
Aug 29, 2001 09:43 PM
