Overheating problem
Old May 20, 2002 | 10:59 PM
antnyws's Avatar
Overheating problem
I have an 89 Camaro RS, when I drive to the college which is about 10 minutes away the temperture starts to rise. Then I flip on the AC, and it drop tremendously. Any response will do. Thanx
Old May 20, 2002 | 11:16 PM
89camaroRSV6's Avatar
what temp are u taling about
ur engine temp - then ur temp sender is porbbly shot..tomp knows the replacement part number ask him
also A/c increases engine temp never does it reduce the temp...
as more load on the engine = more heat
if its ur body temp ....then i cant answer this one
Old May 20, 2002 | 11:25 PM
antnyws's Avatar
it's the engine temp, the one that is next to the spedo
Old May 20, 2002 | 11:30 PM
i remember mine used to do that too... remove the sender unit on the drivers side head behind the A/c and replaced the sender and it should be fine...
mostly its ur sender unit that goes out...
i replaced mine with a mechanical gauge ...the sender unit there now houses my mechanical gauge sender unit ..the mechanical gauge is more relaible and reads temp even after i swithc the engine off since its all mechanical...
i eventually put in the electrical sender unit on the other side in the line going from the waterpump to heater valve..
either way replace the sender unit first wait for the car too cool down and then remove the sender unit and replace it ..its about 7 bucks from autozone and remember to use some liquid gasket / copper gasket (i donno if u can use teflon tape since the unit needs to be grounded) to seal the new sender....
Old May 20, 2002 | 11:38 PM
OnixV6's Avatar
for 4th gens, turning the A\C on automatically turns on the electric radiator fan. some peeps use this trick to keep the engines cool before they get to the staging line. might be the same for 3rd gens with electric radiator fans???
Old May 20, 2002 | 11:45 PM
yeah thats possible too
ur fan might not be turning on on its own
when ur car runs hotter than 200*f
see if the fan comes on
if yes then its the sending unit
otherwise its ur fan
(i completely forgot the fan part..my fan is wired to a switch....)
Old May 21, 2002 | 12:40 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Dude, I live in Sierra Madre.
Old May 21, 2002 | 01:47 PM
antnyws's Avatar
right on
Old May 21, 2002 | 09:40 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
The same is for our 3rd gens as well. When you turn your ac on the fan is suppose to stay on until you turn off the ac.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
