idle speed :confused:
Old May 29, 2002 | 05:12 PM
aaroedg's Avatar
when my V6 engine is cold and i start it up the rpm's come in waves, like the gas was being pushed slightly every few seonds, only when cold though. whats up?!
Old May 29, 2002 | 10:31 PM
theladiesman02's Avatar
my does that too i was trying to find the answer also about that
on ur rpm gauge is the needle allready at like 8 around that area
Old May 30, 2002 | 02:29 PM
aaroedg's Avatar
i don't have a tach yet i just listen
Old May 30, 2002 | 02:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My car's been doing that lately, too; haven't had time to track it down. I'll let everyone know when I do!
Old May 30, 2002 | 03:12 PM
SAEspinz80's Avatar
haha....thats wierd. I swear everytime I used to start my car up in the morning it would do the normal surge to about 1800 and slowly settle down to 800. Then all of a sudden about a week ago, when up and them came down and almost stalled, then went up, and then back down. I never really remembered ever doing it before. So its funny you mention that your cars are doing it too....hhmmm...but mine only does it in the morning after sitting, sometimes....its not an everyday thing....at least not yet.
Old May 30, 2002 | 06:03 PM
aaroedg's Avatar
Yea, it's wierd, but mine isn't as extreme as yours, i mean it is noticable in sound and rpm but it doesn't even come close to stalling.
oh and if it makes a diff - 86 camaro 2.8l mpfi 30,000km on engine.
Old May 30, 2002 | 08:45 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I could have sworn that your car does that to warm up your engine. Mine has done that every morning and most other cars I have do to. Could this be a problem?
Old May 31, 2002 | 03:43 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
On cold startups my car goes up to around 1400-1500 and holds steady, slowly dropping to 700 where it normally idles. It doesn't jump around at all.
Well except when it completely warmed up it jumps around about 100 rmps between 6 and 700, but cold starts are fine.
Old May 31, 2002 | 08:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Elevario, no, when your car is trying to warm itself up, after you start it, it will idle high (like, 1000 RPM or higher), but it will be a steady idle. After the car warms up, the idle will drop to normal (600-800 rpm).
Old Jun 1, 2002 | 02:05 AM
BitchinRS's Avatar
Gezzz I wish 600-800 RPMS was a normal idle for my car. It seems to like idling at 1000 RPMS. This is down from 1500RPMS. If any one has any clues on to get it come down with out turning the idle screw that would be great. I all ready fixed all vaccum hoses and all of the usal supects.
Old Jun 1, 2002 | 02:41 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
unhook your EGR, just plug the vacuum hose off. i went through a whole spew of things. i ened up reinstall the EGr system and quickly found that with it hooked up my idle did that lop thing, like someone givin it a small amount of gas then letting off, over n over n over.
I pluged the EGR vacuum hose and it went away. Nice smooth idle at 1000rpm. no lopin
Old Jun 3, 2002 | 06:27 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
my idle goes up and down too from a cold start
Old Jun 3, 2002 | 11:37 PM
aaroedg's Avatar
1000 aint to bad mine is at 900 when warm
Old Jun 5, 2002 | 12:37 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Check, clean, adjust or replace your IAC, sounds like a sluggish IAC, they like to die on our cars. If you can floor your gas petel and the sucker takes off, YOU don't have injector problems.
Old Jun 5, 2002 | 08:31 PM
BitchinRS's Avatar
I know I have one injector that is running lean all of the time, but my throttle respones is fine. I have cleaned and then replaced my IAC unit. It has left me confused for a long time. It gets a regular tune up and just about all of the ignition compents have been replaced.
someone972
Aug 30, 2015 12:52 AM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
