third brake light mod
Old Jun 10, 2002 | 11:39 PM
Bluerocket's Avatar
Ok the 86 thirdbrake lights have four bulbs in them I was wondering if I could make the ones on the ends blick with the directional. I think I would need to replace them with the two filiment wires and then add the blinker wires to the second filliment. Is it that easy?
Old Jun 10, 2002 | 11:57 PM
Camar_Hunter_c's Avatar
Re: third brake light mod
is that about all that has to be done?. Yes. Easy NO.
Old Jun 11, 2002 | 11:03 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I take it you've seen what the bulbs look like inside the '86 stop light (only year to have it on the OUTSIDE top of the glass)? I didn't know they made those bulbs with dual filaments. I think it'd look cool, though. You might have trouble running the wires to the inside of the car; somehow, I think your only option is to drill through the glass. Either that, or hide a wire that runs up the top of the glass to the inside of the car.
Oh- if any of you '86 guys find out your defroster comes on when you hit the brakes, here's the deal. The wire has "fallen" from the window, and is resting on the hatchback window's gas strut. When you push the brakes, you're giving the defroster power. Solution? Resolder the third brake light wire to the hatch glass.
Old Jun 12, 2002 | 10:42 AM
Bluerocket's Avatar
Nope wont work I can only make the hole thing blink becuase there is no way to get the wires to the bulbs. Maybe if I had the light on the fin I could get that to work.
Old Jun 12, 2002 | 01:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I was thinking about this last night... know the two bolts that hold the '86 third brake light to the glass? What if you drilled a hole in the center of one? Would you be able to push thin wires thru the hole and into the third brake light housing? Just don't mess the torx hole up in the center of the bolt...
That'd be a lonnng drilling time, too....
Old Jun 12, 2002 | 03:11 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
hey tom, do you know why when i push on my brake the 3rd brake light doesn't come on, i have an 86 on the hatch glass, and it used to work, and then sometimes when i had somone hit the brake and i lift the hatch a bit it would come on, and also i have the pull down hatch motor if it would make a difference
Old Jun 12, 2002 | 10:49 PM
Bluerocket's Avatar
THe brake light will have a contact plate for the third brake light on the plastic on the part buy the locking mec. It is not contacting right. Hey Tomp maybe If I found Wire like what they use for the defrost I coul run the wires up the glass and true the hole where to torx bolts are. I woul have to take my time and make sure I did not sracth the wire. The other way is to place a device that senses the blinkers using radio fregencies some what like a remote control.
Old Jun 12, 2002 | 11:10 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
yep, that window brake light sucks bigtime. it was one of the first things I removed, didnt work,would not work. I Just slaped a sticker over the two holes.
its legal if it does not work but the law says it must be there.
but screw em,
to not get pulled over,least in ohio.
you only need 1 tail light and 1 brake light.
and you only need the left head light to work. and if your turn signals dont work, just use your arm.
if you have two side mirrors, you can block out or paint over your rear window.
now I beleive you still must have a rear view mirror even if you cant use it. that is if they wanted to be a d!ck. but i think they can use that for an excuess to pull you over.
Old Jun 13, 2002 | 10:17 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Check the connections, also, to that plate by the hatch latch. You can remove the rear hatch plastic panel with either a big screwdriver or one of your car keys. The '86 design completely sucked; it was GM's first attempt at a 3rd brake light, and that's why the light's changed for '87.
Old Jun 15, 2002 | 09:04 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
I have somewhat of the same prob. It works sometimes. But I've never had anyone raise the bacl glass though...
Old Jun 15, 2002 | 09:12 PM
Bluerocket's Avatar
also check the inside of the third brake there are wires that get loose and when you hit a bumb it stops working. mine did that till I soldered the wires.
Old Jun 17, 2002 | 07:14 PM
Car: 1986 Camaro SC
i got it to work right, all it was , was a couple loose connections and a bit of corrosion, going for my inspection tomorrow, and hopefully ill pass and be on the road soon....
Frozer!!!
Jan 19, 2024 04:55 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
