remove 110 speed limiter
Old Jun 21, 2002 | 09:32 PM
RPS's Avatar
RPS
how can this be achieved?
i heard of temporarily disconection the vats gear sensor thing, but it had a side effect of turning off the speedometer.
is there a way to keep the computer from cutting fuel at 110?
Old Jun 23, 2002 | 11:15 AM
camaro89dude's Avatar
my 2.8 can go faster than 110,
the guy before had teeny tiny lowrider tires on it, and i guess he had the computer reset for them. well, i bought tires that were a little bigger than stock size, and now the speedo is about 10mph off. i can go up to where my speedo says 109 and be going about 120 (or more??)
so just change your tires
Old Jun 23, 2002 | 11:19 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
reprogram your PROM
Old Jun 23, 2002 | 11:21 AM
you can do that, but it will only buy you another 10MPH or so............................
Old Jun 23, 2002 | 01:44 PM
RPS's Avatar
RPS
what tools and where can i get them to reprogram a prom? i have a jet stage II chip
ps will a 140mph camaro speedometer cuage cluster fit into my 92, and have the correct #'s?
Old Jun 23, 2002 | 05:21 PM
if you have a JET chip , i believe your govenor should be removed already
correct me if i'm wrong please
Old Jun 23, 2002 | 06:07 PM
Camar_Hunter_c's Avatar
No your right. It SHOULD be gone...
Old Jun 24, 2002 | 02:29 AM
RPS's Avatar
RPS
"if you have a JET chip , i believe your govenor should be removed already"
nope the damn bugger still exists... hit the limiter on my way home tonight...
Old Jun 24, 2002 | 01:25 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
<--- scared to go above 100+
Old Jun 24, 2002 | 01:42 PM
SAEspinz80's Avatar
WWasem......same here, and I have.....been up to 110....not sure if i hit the limiter cause I got off it and didn't test it....
Old Jun 24, 2002 | 02:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What's the year of your car, RPS?
Old Jun 24, 2002 | 03:30 PM
89camaroRSV6's Avatar
i dont think its ur limiter...
im guessing here either ur ignition system cant hold up / ur injectors cant pump enough fuel.....
what coil,wires,plugs do u have ?
also whats the injectors u have..(mostly its just cause of the injectors- old )
Old Jun 24, 2002 | 10:29 PM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
Governor at 110 MPH??? I have an 85 2.8 and I have gone at least 120...I flew past my buddy who was already doing 120 so I was probably going faster...and I never felt anything kick off...This brings me to another question...Where is the governor on our cars???Is it inside the transmission or something like that...cause I know for a fact that my car goes well above 110 without that kicking on...however...its not really healthy as the car was shaking and I was scared of something in the front end breaking off....haven't had the car over 75 since...
Joe P
Old Jun 25, 2002 | 04:13 AM
the govenor is not an actual, physical thing..........its data programed inside your PROM that tells your engine to shut off when it hits 120 (?) MPH
obviously, its a safety feature
Old Jun 25, 2002 | 09:00 AM
Usually its around 110-115.
and yes the signal that turns on the limiter is from the speedo. Kill that signal go faster. So you "COULD" wire a "KILL" switch when you go highway top end.
Old Jun 25, 2002 | 12:15 PM
but that way u will also lose ur speedo...(since u have to cut the voltage from the VSS to speedo/computer)
so ull have no idea how fast u are going...
Old Jun 25, 2002 | 02:02 PM
RPS's Avatar
RPS
i was wondering if there is a better way than just cutting the power to the vss,
i have a 92 camaro 3.1
a new accel supercoil, little older accel 8mm wires, new bosh platinum II"s
its pretty stable at 110. dosent shake to much
my ignition systems are pretty new... the fuel will cut at exacty around 112. every time.
i have new pirelli 225 p4000's the speed rating is above 120.
Old Jun 25, 2002 | 03:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Joe, there is a governor inside the automatic transmissions, but it's name is misleading; that governor actually controls the tranny's shift points, not the vehicle's speed.
Old Jun 25, 2002 | 06:19 PM
camarokev400's Avatar
i have an 86 2.8 litre 5 speed and i have had it well up over 120 mph messing around with my buddies racing on the back roads, and i have yet to hit my govenor i really do not think my car has one in it, and if it does it is set for over 130 mph
Old Jun 25, 2002 | 09:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
not till the late 80s early 90s did they install the 110 kill switch. only reason they did that was, Gm and other mans. dont put the best of tires on a car. so they can only let the car go as fast as the speed rating of the tires.
not many places are gonna put a z rated tire on any car, they are 160+ rated. next step down is around 110.
Old Jun 25, 2002 | 10:00 PM
RPS's Avatar
RPS
anybody want a 110 video so they can see how it stops at 110?
Old Jun 25, 2002 | 10:34 PM
JaizRed's Avatar
Car: '83 Camaro Berli | '86 T/A WS6
Engine: 5.7L | 5.0L
Transmission: TH-700R4 | TH-700R4
Axle/Gears: 3.08 Drum | 2.73 Disc
heh.. I had my '90 runnin' good the other night... the speedo goes to 110... the needle was past the "h" on "MPH" and still going... how fast would that be?? around 120 i guess? heh. i love to race new cars/trucks... especially ford trucks... who the hell ever heard of a 99 mph limiter?? LOL ferd suxz
Old Jun 25, 2002 | 10:55 PM
AFrikinGoodTime's Avatar
This is a hairbrained idea but here it goes.
For anybody that wants to defeat the limiter + gain a higher mph speedo, here's what you do.
Lets say you have 2.77 ratio gears in the rearend. Your speedo gears (VSS) are matched to this. Purchase new drive & driven gears(Behind the VSS) for a 3.70 rearend. SLP sells these gear sets for $26.90.
Now when your speedo is reading lets say 100mph, you are probably actually doing in the neighborhood of 120- 130 at a guess.
This is where it gets tricky. Next have a buddy drive next to you in a car with an accurate speedo and simply record every lets say 20mph increments. If he is doing 20mph and yours reads 16mph, make a note. Next, if hes doing 40mph and you are doing 31mph, make another note, etc...
Now with these speeds recorded, repaint the # on your speedo to match.
Again, its hairbrained but it works!
beastin91rs
Oct 9, 2015 07:38 AM
perZ
Aug 15, 2015 01:17 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
