mfi tpi and tbi
Old Jul 26, 2002 | 04:47 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
mfi tpi and tbi
whats the diff? i have a 2.8L v6 multi port F1 and would like to know what it is, i was looking through chips for them, thanks
Old Jul 26, 2002 | 11:25 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
mpfi has 6 injectors, one for each cylinder, and a air only throttle body on the upper front of the engine. tbi has a dual injected throttle body on the top of the engine, and will have a dorkie looking air cleaner, assuming your all stock.
Old Jul 26, 2002 | 11:58 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
that pretty much said it all, pretty sure though that some of the TBI units are equipped with a single injector, thinking that those units were on 4 cylinder cars though, (the 4 cylinder bird, and small 4cylinders all the way into the 90's). TBI was also used on chevy trucks and whatnot, nto to mention of course f-bodies, it's more or less rich carburation, or poor fuel injection, it's also very easy to mistake a TBI engine (with aircleaner on) for a carburated engine, because they look nearly identical. Then, there's MPFI , which is very similar to TPI (tuned port injection) MPFI stands for Multi Port Fuel INjection, and as stated earlier has six injectors each feeding an individual cylinder, seven if you count the cold start injector. Fuel is injected into the manifoldand through theh heads into the cylinders, which is a much better design then the TBI units. The difference between MPFI and TPI are the tuned intake runners on TPI. The ressemble tuned headers, and TPI setups often resemble a spider.
Old Jul 27, 2002 | 07:55 AM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
ok so since my engine says multi port F1 its the mpfi?
Old Jul 27, 2002 | 09:51 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
yup, absolutly no go mod it and kick some TBI azz!
Old Jul 27, 2002 | 10:11 AM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
what would be some good starting out mods for the engine? i mainly just want take off increase
Old Jul 27, 2002 | 10:59 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Here's some of my stuff, my pages aren't finished yet, but feel free to browsome, most of its is notes...
http://members.fbody.com/sixtydegree/tuneup.html
http://members.fbody.com/sixtydegree/ignition.html
http://members.fbody.com/sixtydegree/chassis.html
http://members.fbody.com/sixtydegree/Exhuast.html
Old Jul 2, 2010 | 07:07 AM
hasty88-and-89's Avatar
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
Re: mfi tpi and tbi
YOU THINK A MODDED MPFI 2.8 WOULD BEAT MODDED 5.0 TBI
Old Jul 2, 2010 | 09:06 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: mfi tpi and tbi
You're 8 years late dude....
Old Jul 3, 2010 | 10:41 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: mfi tpi and tbi
XD I was wondering why all that guys links didn't work...
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
