Question on Mom's car
Old Jul 27, 2002 | 10:11 AM
WaynesRS's Avatar
My Mom has a 89 3.1 grand prix . I drove it for awhile yesterday the temp gauge never rose up any . Im thinking its either the Temp sending unit . Or maybe the thermastat is stuck open . Is there a way to tell if the thermastat is sticking without putting it on the stove in a pot of boiling water . Or would this be somethinge else besides the temp sending unit or thermastat . Thanx guys .
Old Jul 27, 2002 | 03:07 PM
WaynesRS's Avatar
ttt:lala:
Old Jul 27, 2002 | 03:55 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
how long were you driving it for?
Old Jul 27, 2002 | 05:51 PM
probe the engine coolant temperature sensor with your voltmeter
you should see XXX amount of volts
if you see that, then you know your gauge is most likely the bad sour banana
Old Jul 27, 2002 | 06:01 PM
whoops made a slight error
you'll have to find out which wires out of the ECM go to the temp gauge
probe them to make sure they are giving power and ground
if they are, the gauge is bad
if not, you have either bad wires, bad ground, short circuit, or bad ECM
Old Jul 27, 2002 | 06:48 PM
WaynesRS's Avatar
I drove it about 7 miles . Then went in somewhere for about 20 min came back out and drove it 7 miles home . When I got to the store , I was just thinking , well , I didnt drive it far enough to warm it up , but then I was thinking my car's gauge would have move up some . So then when I drove it home ,l I kept watching it and it never moved .
Old Jul 27, 2002 | 06:49 PM
WaynesRS's Avatar
Thankyou man .
Old Jul 27, 2002 | 07:27 PM
no problem
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
