Those of you with a Accel super coil
Old Aug 30, 2002 | 11:44 PM
86camarodriver's Avatar
Are you guys runing the stock MM wires or 8mm wires?
I have the stock type AC Delcos and I do not think they can handle the coil but I could be wrong. accel super coil, blue streak cap and rotor, autolite plugs, ac delco wires.
I just don't want to have to spend 80 bucks if I don't have to.
Just trying to work out all the little problems in the car.
David
Old Aug 31, 2002 | 12:12 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I dunno about whether or not you need the bigger wires, but accel superstock 8mm wires for our cars are only $23.95 through summit.
Old Aug 31, 2002 | 01:20 AM
AFrikanGoodTime's Avatar
Larger plug wires just mean more insulation from heat. The first thing to fail on wires is the boot (part that clips to the sparkplugs). To help wires last longer, pick up some braided boot insulators. I've had the same set of taylor wires on this car for 8 years and they still have perfect flow, I check there resistence every time I change the plugs. Yes I do have a hotter ignition system also.
Old Aug 31, 2002 | 11:21 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I have run stock 7mm wires with accel before and it worked fine. But if you do flip for some new wires get the 8.8 Kems. I perfer them over accel wires.
Old Aug 31, 2002 | 10:11 PM
One wire has a burn mark on it from the exhaust manifold and when the engine gets hot the car misses a bit and when I looked in the Haynes manual about a few problems it pointed to plugs and wires. I know the plugs are bad so I many just get the wires from summit since the delcos where at least 20.
Old Sep 4, 2002 | 09:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Er, thicker plug wires also keep the spark "inside" better. The thicker insulation keeps the spark from arcing out to the engine block, or some other ground. When you install your new wires, try your best not to get any grease on them. Oil/grease sinks into the plug wire insulation, and can cause spark leaks.
I wouldn't run a stronger coil on anything less than an 8mm wire. Like Joe said, you can get the Accel's, or there's other plug wires out there that aren't $80. You're thinking of the MSD wire prices.
Old Sep 4, 2002 | 12:43 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Payed 39.95 for some accell "universal" kit wires that had 8+coil wire. Thats all they had on shelf that would work, and I have 2 extra wires case one gets fubared.
Old Sep 4, 2002 | 02:46 PM
RPS's Avatar
RPS
i have the accell supercoil, and i have 7mm bosh platinum wires, so far so good...
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
school boy
Oct 22, 2015 11:47 AM
Dragonsys
Sep 25, 2015 03:51 PM
