What will make it........
Old Sep 28, 2002 | 12:21 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
stall right in the middle of an intersection and not start again. I have lots of fuel pressure. Check engine light is blown so as of now I can't see if there is a trouble code. I did notice on the EGR a bolt is missing and is/was blowing gasses out the side. Will that make it stop running??? Need Help FAST!!!!!!!!!!
Old Sep 28, 2002 | 03:54 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
An external EGR leak shouldn't cause a stall.
Check for spark at 2 plug wires and at the coil wire.
Old Sep 28, 2002 | 04:32 PM
AFrikanGoodTime's Avatar
A broken timing chain.
Old Sep 28, 2002 | 05:22 PM
Dale's Avatar
Engine: 350 S-TPI
Ok, got the CEL working, and it spit out code 32, egr. I replaced it, a vacume line, and 2 spark plug wires. Reset the brain, but now every time I got to start it, it takes 2 trys I'm thinking fuel pump fixing to go out, or injectors are starting to leak??
I am thinking if it continues after the brain should have reset itself getting a FP guage and checking that.
Any other ideas??
Old Sep 28, 2002 | 05:58 PM
Any other ideas??
You just stated up top that you had "lots of fuel pressure"?
If you want help then you need to get your facts straight
Old Sep 28, 2002 | 08:18 PM
Dale's Avatar
Engine: 350 S-TPI
I pressed the "nozzle" as soon as I got done cranking. It sprayed major fuel. If my injectors are leaking, it will cause a drop in pressure. It will still spray even then. I have read that these are very sensative to fuel pressure. If im like 5lbs under, I read they dont run right. Plus that was typed before I got majorly into repairing this.
Old Sep 28, 2002 | 11:15 PM
KED85's Avatar
Here's something I learned about the "Ol Faithful" theory of that "Sputz" coming outta the nozzel.
It ain't a gauge.
YOU NEED A GAUGE.
Honest
Really
Need a gauge.
Low pressure fuel pump can still "sputz" the fuel from there.
Ya need to use a gauge to read accuratly.
I learned the hard way, too.
I ended up replacing my pump, when gauges, it "sputz'd" about 10 pounds, not the 45 or so it should.
Old Sep 29, 2002 | 09:00 AM
Dale's Avatar
Engine: 350 S-TPI
so Ked, your confiriming my thought, I need to get a guage and see if its getting low. Thanks, will do this next weekend.
Old Sep 29, 2002 | 10:21 AM
KED85's Avatar
I would not suggest the "Sputz" test when the fuel pump works correctly.
May cause blindness (fuel splashing into your eyes).
Get a gauge, it'll show ya what's happening.
It's good to change fuel pumps before an engine swap, too.
Better running swap project end results!
Old Sep 29, 2002 | 09:10 PM
Dale's Avatar
Engine: 350 S-TPI
It broke again this morning. So I got a guage, tested at 45lbs, and didnt drop after 5 min. Got code 15, eng. temp. sensor, changed it. Keeping fingers crossed.!!!!!!!!
Old Sep 29, 2002 | 09:50 PM
90FirebirdV6's Avatar
I had a problem similar, where it would start fine in the morning but when the engine got hot if i turned the car off, then back on it took several times for it to finally turn over, i changed the engine coolant temp sensor and it fixed the problem.
Old Sep 29, 2002 | 11:41 PM
JadesAn89's Avatar
I am swapping out a 2.8 for a 3.1 tomorrow and tuesday (i have to work tomorrow so it's a 2 day project ) How hard is it to change the fuel pump and about how much do they cost? I'll look it up also, but wanted some input from the trusty V6 Board here...
Old Sep 30, 2002 | 07:25 AM
Dale's Avatar
Engine: 350 S-TPI
I hear a fuel pump is a pita cause its in the tank. I was SOOOOOO glad mine wasn't bad. We just put a full tank of gas in it the night before.
Old Sep 30, 2002 | 09:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Glad to hear it's not the pump.. it's not a fun job, especially if you do it twice. Now the flow rate could also be down and you could still get adequate pressure, but that's an unlikely scenario, usually the two go hand-in-hand (low pressure & low fuel flow).
JadesAn89, both the 2.8 multiport and the 3.1 multiport motors use the same fuel pump, so you're okay. (AC/Delco part #EP240.)
Old Sep 30, 2002 | 11:42 AM
KED85's Avatar
Gas tank pumps
NO FUN AT ALL!
Hope ya got the 3.1 for dirt cheap.
Plan on more than two days.
Happy wrenching!
PS take off every sensor ya can, clean the part that enters into water passages. It helps.
I spent one whole day alone, on hose reconnections.
Was worth that effort.
Vacuum hose reconnection is the biggest problem & easiest & cheapest to solve.
Electrical problems always cost money!
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
